Question about Bushnell "Insta-Focus" Binoculars
Bushnell Sportview Compact 8x30 focusing problem. Won't tune??
Can't tuneup. I attempt to adjust by covering right barrel and using central focus, objects never come in clear, so I can't go on to cover left barrel and adjust the diopter either. Is there something else I need to know?
  • 112 Answers
SOURCE: Insta-Focus focusing problem
first open and close the binoculars untill they fit you eye width,now adjust left eye with the flat section located on the center hinge,now turn right eyepiece till clear. note: once you have adjusted right eyepiece you only have to leave it in that position in order to focus from near and far.........good luck......larry@reichinstruments.com
Posted on Nov 25, 2008
  • 112 Answers
SOURCE: bushnell insta-focus mechanism gets stuck.
they were famous for that, because the screwpin that holds the eyepice shaft is metal and the groove that it rides in is plastic, and eventually gets jammed....look where you put your fingers to adjust eyepieces. should be small metal plate in center of hinge(sometimes with bushnell logo) that will simply pry off by using small screw driver,and now you will be able to see if the screw is loose or damaged. good luck...larry@reichinstruments.com
Posted on Jan 16, 2009
  • 115 Answers
SOURCE: need new eye cups for Bushnell Banner 7 X 35
call customer service at 800-423-3537 pressing option 1. you will need to send this into repair to procure the parts you need.
Posted on Oct 06, 2009
Testimonial: "Great - got customer service - ordered parts - should be here soon - thanks!"
  • 32 Answers
SOURCE: unable to focus my Bushnell 7x35 insta-vision binoculars
insta-vision bino's are self focusing no adjustments.
Posted on Nov 02, 2009
SOURCE: The diopter setting eyepiece has come out of the
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Posted on Apr 11, 2010
I need replacement eye guards for Bushnell Sportview Insta-Focus.
contact the company directly, they have replacements. also ebay carries parts.
Jul 26, 2017 | Bushnell Optics
8x25 minolta compact bionoculars center focus knob will not turn. Have taken screw off center knob and removed 4 rubber strips on bionocular body and looks like allen? screw underneath. No obvious way...
They don't make these things easy to take apart, or fix. Here's your best shot- take it into a camera repair shop, and see what they say. Some tech might know what you have to do to get it apart, or if it can come apart without damage or special tools.
Unfortunately, only the repair techs know how, and there aren't too many (if any) of them, since they often just charge a set amount and send a refurbished or new pair to the customer.
Wish I had a more specific answer, but good luck to you, and with just a bit, you'll figure this out.
Sep 20, 2010 | Minolta Compact Binocular
I need the windage dial for my Bushnell 3-9x38 Sportview Rifle Scope 74-3938. The adjustment wheel is frozen.
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Mar 23, 2010 | Bushnell 3-9x38 Sportview Rifle Scope...
Sight adjustments
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that very same spot.
To move the scope's reticle up or down, turn the elevation adjustment on the TOP of the scope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
If you want to move the direction the scope is looking left or right, turn the windage adjustment on the RIGHT side of the scope left or right to look where the bullet is impacting. To move the crosshairs to the right, turn it right.
Hope this helps, Mark the Gunsmith
Dec 11, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
I have a Bushnell Sportview 4-12x40 on my rifle
I just took my Sportview 3-9x50 scope apart for same problem. Found that the groove that phillips screw rides in got compressed somehow. With a little prying, I was able to open it back up. THIS IS NOT THE ADVISED WAY TO CORRECT!!!!! Bushnell has a lifetime on this product and will gladly help you. I just f*&^ed my warranty out the window, but need scope Nov. 7 for opening weekend with my daughter!! Good hunting, Pete
Oct 14, 2009 | Bushnell Optics
Just bought a marlin 336 rifle (used) with a Bushnell Sportview scope mounted. How can I get a users manual for it? I'm not even sure what size it is( 4-32? ) how do I adjust it? what is the knurled ring...
Here ya go. link to the users manual.
If for some reason the link doesn't work, go to Bushells site and you will find the link to get a user Manual for this scope. hope this Helps.
LINK
Oct 13, 2009 | Bushnell Optics
I need crosshair cover caps, bushnell scope.where can i find them
butler creek makes scope covers for all scopes. they can be found in most gun shops, if not try Midway usa.com
Dec 17, 2008 | Optics
Missing Parts
That was nice of Bushnell to do that. They didn't have the software available online as well as the manual on their website. I did find this support page:
http://www.bushnell.com/customer_service/contact.cfm?section=Spectator%20Sports
Jul 05, 2008 | Bushnell Image View 8x30 118321 2.1...
Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Mar 02, 2008 | Optics
Optics Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
