Question about Cameras
Hi i recently pressed format on my vivi cam 5199 by mistake now when i put any memory card in the camera it says format error
  • toni_gledhil Jan 13, 2009
    did as said formated memory card it still says format error, tried other memory cards in it and they still say the same. will it be a technical error.
  • 26 Answers
If you format your memory card all files that are saved to it will be erased
Posted on Jan 13, 2009
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
Help my vivitar vivi cam 5026 but looks like a
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jul 04, 2010 | Vivitar ViviCam 3740 Digital Camera
Lens cover does not open and camera shuts off it is a vivi 5385 vivitar digital
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 09, 2010 | Vivitar ViviCam 5385 Digital Camera
My sony dsc-w100 digital camera says format error and hangs on. what shall i do??
Take out memory card from camera, turn it On and check does it show format error?
If yes, press Home, Memory option and format internal memory.
If camera does not show format error then put back memory card in and press Home, Memory card option and format it.
This will delete all files/ data and will refresh memory card, take some pictures and check.
If after formatting, still format error exist, put new memory card.
Nov 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Memory card error
Format the camera and only go up to a 2gb card.
Aug 11, 2009 | Canon PowerShot A520 Digital Camera
Memory card error samsung s1065
when you view pics it is best to download them to a temp file if you don't want them easy to delete. once the cam views them .
Apr 04, 2017 | Cameras
Format problems of Olympus 1Gb card with C-750UZ
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
May 05, 2009 | Olympus Camedia C-350 Digital Camera
Vivicam 5199 transfer fotos from cam memory to memory card
I would look in your manual on this one. I am not familiar with a camera without a memory card. Are you sure there isn't one in it?
Jul 15, 2008 | Vivitar ViviCam 5100 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
What is the best memory card to get and how do I format
my guess, the SD card was too big for this cam to handle..
I had a similar problem suggested recently.
When that user tried a smaller card, they had no problem.
I have used this cam, with a 128mb card and had no problems like this.
Whether the cam can handle cards biger than 128mb, i don't know!
I do have a 2gb card which i bought for my new cam and i will try it in my old vivi 3720, if i experience any problems like those of yours, i will post again.. hope this was of help
Colin
colinfenning@yahoo.co.uk
Nov 19, 2007 | Vivitar ViviCam 3720 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
