Question about Olevia LT37HVS 37 in. LCD HDTV
I want to connect a soundbar to my Olevia 37 inch TV. How do I re-set the audio from variable to fixed?
Menu does not have audio connection to re-set the audio from vaiable to fixed so that a soundbar can be connected.
SOURCE: olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Posted on Oct 21, 2007
  • 45 Answers
SOURCE: olevia lt 27 hv no sound
one way to test the audio on the tv is to connected a cable line or ant.. and see if audio comes out on the speakers of the television.. if they don't then go on the menu under audio and make sure the speakers are not turn off..
If you get audio with the ant or cable channels.. then the television speakers are on.. now you might want to try the sat receiver with different connections an example will be AV cables.. yellow, red and white.. to see if that works ? make sure the red and white are right next to the yellow input or else you wont get audio..
If you will like more help.. you could also contact this company called Amergence Technology they have trained technicians that have knowledge for Olevia products.. there number is 866-965-3842
Posted on Jul 28, 2009
  • 127 Answers
SOURCE: how to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Posted on Jan 02, 2010
SOURCE: Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Posted on Jan 29, 2010
bshldn
  • 736 Answers
SOURCE: I am from India &
When this happens the hdmi board on the television can need to be replaced. However that is the worst cases scenario so before servicing the television in that manner, first try two other things.
1. A hot swap. This is when you remove all the hdmi cables from the television (you might want to remove all cables) and wait 30 seconds before replacing them. During the 30 seconds you are to complete a reset all to factory settings on the television menu. Be sure that you are not just completinig just an audio or video reset; there should be a reset all that will ask you to confirm whether or not you want to reset the television to its initial factory settings. You may also have to unplug the television for 2 minutes after doing this for it to recognize its hdmi input again. Then after the two minutes you can plug the television back in, replace the hdmi cable, turn your television on first, and then turn on your devices.
2. A factory reset. Not to be confused with the reset above this reset goes into the factory menus and resets the television completely, wiping even more settings and completing a "reboot" if you will. This should not be played around with just like the Registry Editor on your computer should not be messed with unless you are absolutely sure what to clear. These settings on the television should not be changed at random because the television's memory could be wiped. Someone knowledgeable about repairing these televisions specifically is the one that should attempt a factory reset or the service menu should be followed very closely by the person that is performing this reset.
Posted on Jan 12, 2011
I have a sharp aquos tv, model LC-42D62U, and had a sound bar attached that worked great. When I remove the soundbar I can’t get the TV sound to turn on. I have trouble shot a lot of things. The problem...
I do not have sharp manuals to reference - in general the TV sound - Variable vs Fixed just allows the set to control the volume output (variable) or Fixed will produce one level of output and your device (soundbar) volume control would adjust up or down from there. There is usually another location in the menu that allows you to turn off the TV speakers so they do not operate at the same time as your soundbar or other device. It should be simply Speaker ON / OFF. If you can locate this - you should be able to select it. If it is all greyed out - that means the TV believes based on the connections / setting / input selection - those cannot be changed. (you may try connecting the device and see if the greyed out menu items turn back white or are selectable. Sorry I don't have a specific answer - hope this helps
Dec 21, 2017 | Sharp Televison & Video
Do I need to turn off the tv speakers to get tv sound from my soundbar?
How to Connect Soundbar to TV audio
I would think that the tv would automatically detect a cable being plugged in. It should only send sound to the soundbar once it is connected. Make sure the soundbar is on when you do your testing. You may have to change the audio settings on your tv in order to send audio to the soundbar.
Sep 07, 2016 | Televison & Video
Have bought a polaroid soundbar tb301 to work with my polarooid p43d300 tv what setting do i need to set tv to
Could not find a Polaroid TB301, so we'll have to guess.
Press the Menu button on the remote and use the right and left arrows to select AUDIO.
In the AUDIO Menu, use the up and down arrows to select SPDIF Type.
If the sound bar is connected to the TVs Digital Audio Out, (it plugs into the socket with the red light) select Dolby Digital.
If the sound bar is connected to the TVs R/L Audio Out, select PCM.
Jun 29, 2016 | Polaroid Televison & Video
How do I connect my Sony soundbar ht-ct 260h to my blu ray player etc, I have no optical port or arc hdmi port,at the moment connected through the audio lead to soundbar & tv ?
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Mar 30, 2015 | Sony HT-CT260H Soundbar and Wireless...
How do I hook up a Yamaha RX-V377 receiver to a Samsung HW-H450 soundbar?
Not sure why you would want to set things up this way, but you have to set the audio output in the receiver hdmi setup menu to tv. This will allow the receiver to pass audio info out of the hdmi jack. By default, this is turned off.
Jan 29, 2015 | Yamaha RX-V377 Receiver 5.1 Channels, 70...
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
I connect my I live soundbar to my Samsung plasma TV and I'm not getting no sound from the TV to soundbar please help
Check the TV's audio menu to make sure there will be signal available at the RCA outputs
Some sets won't allow both internal & external speakers/sound bar to both be on.
Jan 07, 2015 | Samsung Televison & Video
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
How do i connect a soundbar to a Sanyo TV.Tried all connections with both RCA cable and 3.5mm Line in cable.No luck.thanks
Make sure you are connecting to the TV's audio-OUT jacks, not the audio-IN jacks. Also, check the TV options menu. Some TVs have a choice of internal or external speakers and you have to select one or the other; obviously, you would select "external".
On the soundbar make sure you have selected the correct input jack for the audio cable.
Sep 26, 2014 | Sanyo 42 in. LCD TV
Cant connect a rca soundbar to my emerson tv
If your Emerson TV has a digital coax output connector identified as such and your RCA soundbar has a digital coax input connector, you will have to purchase an appropriate cable and connect it. Some soundbars, such as Vizio, have left and right RCA audio inputs to match similar outputs on a TV set.
Jan 09, 2014 | Televison & Video
Olevia LT37HVS 37 in. LCD HDTV Logo
223 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
