Question about Whirlpool GEW9250 Electric Dryer
Dryer was working fine then quit heating,I took off front panel and cleaned but still no heat.
  • 686 Answers
Change thermal fuse go to www.repairclinic.com enter model # and see all your parts
Posted on Mar 12, 2009
My dryer is not heating up. The ignitor glows but the gas does not ignite. I took of the front lower panel and watched it. It doesn't ignite. The gas line is fine. What can it be?
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Jan 13, 2009 | Whirlpool GEW9250 Electric Dryer
My Kenmore Elite gas dryer only heats some of the time
Took the bottom front panel off and cleaned the dust from there and cleaned it out real well. An animal had nuts in the vent from out side. Put new hose on and started it up and is working fine.
Thank you anyway. Lynn Miller
Jan 09, 2009 | Kenmore Elite HE4 Electric Dryer
LG DLG2524W DRYER WORKS FINE EXCEPT DOESN'T HEAT UP
1. Open dryer door and remove the phillips head screws at the 5 and 7 O'Clock positions. 2. Remove three screws at very back, allowing top cover to be moved back about an inch and lifted off. 3. remove screw at top left and top right from front top panel. 4. pull plastic front panel along top edge to release front top panel. (watch for sharp edges) 5. Swing top up and over onto top of dryer. 6. Unplug light and door switch. 7. remove four screws at top of large lower panel. 8. lift panel up a bit and off. 9. unplug sensor plug at bottom allowing panel with door to be set aside. 10. gas dryer has dime sized high limit thermostat on left front side of burner chamber. Has two wires on it, with a small pin in the center. Push the pin in. Reassemble and clean out vent, eliminating flexible venting, replacing with rigid aluminum piping and elbows. Outside vent should have a four inch vent flap opening, not just a two inch if it is that style.
Jan 03, 2009 | LG DLG5932W Gas Dryer
Dryer won't heat
If it is an electric heater that means that either the heating element,or the thermistor , or the cirrcuit breaker connecting the element mustbe replaced.
You find diagrams and replacement parts here, just enter the model number.
See also following suggestions from repairclinic :
There's no heat.
How Dryers work
Find a part for your Dryer
Oct 14, 2008 | Malber WD1000 Front Load Washer/Dryer
Whirlpool GEW9250 Electric Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
