Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Mixer Head Wobbles
My mixer head has started to wobble while in use. I'm not sure when it began, but noticed that my moms does not and realized that mine does. I do not have a problem with the paddle hitting the bowl. I have tried adjusting the paddle using the adjustment and it didn't really help the problem at all, so I put it back in its original position. Not sure what else could be causing this, any thoughts? I also can't find my manual to see if its listed in it. My mixer is about 3 years old now.
  • jpalm285 Mar 15, 2009
    My mixer head not only wobbles, but jumps. I read what cactus bob wrote, and I'm really mad. This mixer is about 8 years old, and was not cheap.
Fixed it!!! My mixer had the same problem.  It was a hand-me-down...
Okay, so I lifted the head and looked down into the pivot where there is a screw (looking from the front of the mixer).  I took a flat-heat screwdriver and turned it counter-clockwise.  (It took quite a few turns, the screw came out a few millimeters.)
BUT when I lowered the head, hurray!  No more paddle rubbing against the bowl!  No more head jumping up and down!  No more wobbling in the "locked" position!
Try it!
Posted on Apr 08, 2009
    President:
  • 267 Answers
Head berrings are worn out , you cannot fix this . sorry to say this is not you grandmoms kitchenaid there just not made to use anymore ....... good luck to you
Posted on Jan 15, 2009
Kitchen Aid stand mixer head doesn't lock down and wobbles
You need to do a couple of strokes with a rat tail file at a 30 degree angle at the top of the slot the head lock engages into. You will need to remove the hinge pin to do this. A Kitchen Aid agent will have done plenty of then so it won't cost an arm and a leg to get it sorted.
Nov 17, 2012 | KitchenAid KITCHEN AID 5 Quart Artisan...
My kitchenaid stand mixer arm wobbles when I turn it on.
if the head wobbles on stand, flip mixer upside down, and tighten the pivot pin screw way deep down inside stand. you will need a long flat blade screwdriver. it's probably loose.
May 13, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer is a lift-top and the top seems to be loose and wobbles as it mixes. help?
Hi, W/D here.
If you raise the head of your mixer, and look under the raised part, you'll see a silver screw head with a slot for a standard bladed screwdriver. Tighten that screw, and that should do it.
Best regards, --W/D--
please feel free to rate this solution!
Jan 31, 2011 | KitchenAid 32685 Mixer
Top wobbles and beaters scrape bottom of mixing bowl when in use
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 08, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixer head is wobbles. is there a way to tighten it?
I am guessing you have a model where the head tilts back. There is usually a pin that runs through the base and head hinge. Check that this is centered and not sticking out on one side. If it is, knock it back so it is even then tighten the screw underneath that holds it.
Jan 23, 2010 | KitchenAid Food Mixers
KitchenAid wobbles when mixing
Do not store or transport the mixer on its side ever. Always upright. The grease in the gearbox should even out eventually. Try sitting on it when it wobbles. At least yours works.
Dec 26, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Dec 14, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer head wobbles
is it the mixer head or is it the beater paddle? i will need to know which one it is.
Oct 29, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
813 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
