Question about ATI FirePro 2460 PCIe Video Card
Ati firepro 2460 does not display monitor and disables onboard video
DickCanFixIt
  • 948 Answers
SOURCE: Cant utilize extended monitor function in XP w/ onboard chipset as other VGA out
You cannot use both the onboard video and a separate card at the same time. Are you trying to use multiple monitors? Your video card must support that if you are, and the Radeon 7500 does not mention that it does. If it does, the ATI Catalyst drivers will have the option.
Posted on Jun 02, 2009
  • 38 Answers
SOURCE: How do I disable the onboard video in a Gateway
try in settings of gpu in bios.....
Posted on Apr 06, 2010
akashbnsl31
  • 56 Answers
SOURCE: II want to clear
no...............
Posted on Nov 26, 2010
  • 19 Answers
SOURCE: I have issues with the
In order to further troubleshoot this issue, I would recommend the following:
Uninstall the ATI drivers from your computer.
Shut down the computer.
Remove the ATI card from your computer, and connect your monitor to the onboard video adapter.
Turn on the computer.
Ensure the ATI software was infact removed.
Reinstall the ATI video Card
Turn On the computer
Reinstall the ATI drivers ensuring to select the proper "CrossFire" configuration
Posted on May 21, 2011
joecoolvette
  • 5660 Answers
SOURCE: connect a vga display to a ati firepro 2460
ATI FirePro 2460 graphics card,
http://www.amazon.com/ATI-FirePro-Mini-DisplayPort-PCI-Express-100-505610/dp/B003N75ZCA
Uses four Mini DisplayPorts,
http://en.wikipedia.org/wiki/Mini_DisplayPort
Use this Mini DisplayPort to female VGA adapter,
http://www.amazon.com/Mini-DisplayPort-VGA-Female-Adapter/dp/B002WUVAVE
(The VGA monitor cable has a male VGA connector )
Regards,
joecoolvette
Posted on Feb 18, 2012
Hello, How can I setup my 4 monitors using a FirePro V7900? I have it on a Dell precision T7500. All the monitors are connected and detected by the graphic card Right now is working with only 2 monitors...
Hi, If u see on the bottom right corner of the task bar their is a red icon for ATI Catalyst Control Centre.Open it and on the top left corner of that their is a drop down menu, In that menu select Desktop and Displays.in that you will see all four monitors if not then theirs a button for detect displays, when u click on that button all four monitors will start showing on the window in the console.now u can set any one of them as primary monitor and respectively others as secondary and so on..Then click ok and thats it..
Sep 07, 2011 | AMD FirePro V7900 2GB PCI Exp 100505647...
I have issues with the second ATI FirePro V7800 card. I am running Window 7 pro - 64 bit. The motherboard is ASUS Sabertooth X58. Intel Corei7. Corsair 24 GB. Both two cards were working fine...
May 21, 2011 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
Instaling video driver problems
You may need to change priority for onboard/PCIe in BIOS. Or to disable onboard video chip.
Dec 01, 2009 | Asrock P4i65GV Motherboard
I have 2 acer data managerment problem found in edata security software installation it says please close all running programs and reinstall edats security. the second one is catalyst control center is not...
Close programs (word-processor, web-browser).
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click on EDATS SECURITY (or something approximately that)
Click Remove
Click OK
Shutdown
Restart
Reinstall the software
> catalyst control center is not supported by the friver [?]
> version of your enabled graphics adapter.
ATI (www.ati.com) distributes the "Catalyst" software with their adapter video-cards. So, there is a problem with the "Control Center" component of their software.
> please update your ati graphics,
> or enable your ati adapter using displays manager
First, do you have an add-in video-card in your computer?
If not, then you should not be trying to use the ATI software,
and you should remove it:
* click Start
* click Control Panel
* click Add/Remove Programs
* select the ATI Catalyst software
* click Remove
* restart your computer
Second, if you have added an ATI card, you may need to restart your computer, press DELETE to enter BIOS SETUP, and "disable" the "onboard" video-adapter, or change the video-priority so that the ATI video-card becomes the "primary" video-adapter, and the onboard video-adapter becomes the "secondary" video-adapter.
Then, click Save Changes, and before selecting Exit From Setup,
move the video data-cable from the onboard VGA port to the VGA port on the ATI video-adapter. Then, "blindly", click Exit, and let your computer restart. Then, during the reboot, the ATI software will recognize the new "primary" video-card, and will the software will control the ATI video-hardware.
Sometimes, it helps to have a second computer monitor, and connect one adapter to the "onboard" VGA-port, and the other to the ATI VGA-port, so that you can see video output wherever it is produced.
Nov 09, 2009 | Acer Computers & Internet
Can i put a ati radeon 9550 graphics card in a dell dimension 2400
You can put any graphics card in any machine you just need to install the proper driver
Use to be a jumper on the mother that disabled the onboard video but today I think the soft hardware saves use the trouble.
You can run 2 monitors at one time using the 2 video graphics... card and the one on board just set you display properties
Jul 30, 2009 | ATI RADEON 9550 Graphic Card
ATi radeon HD4650 issue
First enable you onboard video the connect your monitor to it. Insert you ATi video card in the mother board. Boot up. Install the ATi driver. Shutdown. Trasfer the monito to ATi video card. Then enjoy with you new vedeo card!
cheers!
Jul 18, 2009 | Computers & Internet
Jun 02, 2009 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Will ati card work in one monitor
Be sure that you have gone into your Bios on your computer and disable the onboard intel card that your using.
Aug 27, 2007 | ATI RADEON 9250, (256 MB) PCI Graphic...
ATI FirePro 2460 PCIe Video Card Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
