Question about Dishwashers
Hi. I have a blomberg dishwasher. it doesnt working and has a message: call service. we found that the bottom of it, on the floor is watery. what is the problem??? what we should do??
3 Suggested Answers
SOURCE: Water is settled at the bottom. Filters have been ...
My dishwasher did the same thing after a cycle was interrupted. Try putting your hand under the handle and firmly pushing against the top center of the door so the actuation of the switch is completed (the switch is in the door on my model and I suspect the actuator's travel is not getting completed).
Worked for me after pushing every combination of buttons and waiting for anything to happen.
PS: I pressed the START/CANCEL button during power up and the display showed IF for 5 secs then showed alternating H/H6. Anyone know what that means?
Posted on Dec 25, 2010
taran_2005
  • 10515 Answers
SOURCE: blomberg dishwasher dw14110 i got wter
Look under the sink where the drain hose from the dishwasher hooks up and make sure the hose dont just drop down and it goes up higher than the drain pipe and then down to the dishwasher ,, water is running back down the drain back into the dishwasher.
Most always keep some water in the tub but if there is water every time then the pump is not pump all the water out ,, pull the d/w drain hose off under the sink and hold it into a bucket and run the d/w in drain mode and if all the water drains from the d/w then you have a house drain problem and need a plumber and if not then you will need a new pump and this is something you will need a tech to come out on.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 21, 2010
How to get **** off of the bottom of the dishwasher
There are many sites telling how to clean a dishwasher.
Just search for "How to clean a dishwasher."
Here is one link.
Your Dishwasher is FilthyHere How to Clean It
Aug 03, 2014 | Blomberg Dishwashers
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
My Blomberg dishwasher will not stop draining once all the water is out. It is at the beginning of the cycle and it's like its stuck and won't move on to the next part of the cycle to bring water...
Doug Smith\'s solution of Oct. 20, 2008 worked for my Blomberg Dwt57500ss model.
Removed small filter basket by pinching 2 tabs inward at the top of the basket. Turned larger basket counter-clockwise by hand and lifted out stainless steel screen. Used wet/dry vac to suck all the water out. The anti-flood switch reset itself. Turn power back on to unit, and pressed start. Then pressed program I wanted to use and reset button to start machine. Worked immediately and started washing dishes.
Sep 05, 2011 | Blomberg Dishwashers
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
Water leaking from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uiopety
Apr 07, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
