Quasar tv has small screen in bottom right corner any ideas on how to get it off The screen?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not unless you find with the remote or in the menu it has a PIP or picture in picture feature which is what it sounds like, many you will need the original remote to remove or adjust that--check menu first for CC or closed captions, and if you are using a cable or sat box that also has the CC.
Posted on Dec 11, 2012
3 Suggested Answers
cTech1
  • 66 Answers
SOURCE: Dark screen on TV
This sounds like a speaker got too close to the TV.
Degauss is built into many tv's check for it in the menu.
Otherwise, yes a TV shop or yourself will need to degauss the TV.
Posted on May 15, 2008
  • 3 Answers
SOURCE: how do i get rid of the number 03 in the bottom
BY LIKEIN A DOGZ BUM
Posted on Jan 19, 2010
Horizontal lines and black spot in corner of led tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 09, 2016 | Samsung Televison & Video
What does the small rotating circle on the top right hand corner of my sony bravia mean?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2014 | Sony BRAVIA KDL50EX645 50 Inch 1080p...
My TV says "line" in
Change the input....
Jun 30, 2011 | Quasar SP-2722 27" TV
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
Polaroid TLX-04240B going to a black screen after running for 2mins. Any ideas on how to fix this?
open the black plastic panel and the aluminum panel which has 3 screws each in the back of the tv.
look at bottom left corner of top board. to the right of the red led light,
there's these four white small switches. turn the bottom two switches to "on" and tv should be working.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Jan 04, 2010 | Televison & Video
Tv locked
Enter all Zeros, if that does not work try 1234 or 9999.
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
Feb 02, 2009 | Quasar SP-3235 32" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Red colored halo at bottom corners of screen
Movement of any TV can result in a problem caused by bad
solder connections.In your case, the red convergence IC......
Found on a circuit board,mounted on large heatsinks........
Part # STK392-040.....Change both for prevent maintenance.
Do not use generics - I use OEM or better = Sam,Pan,Hitachi.
After repair,recheck alignment................T.
Nov 20, 2007 | Samsung PCJ533R 53" Rear Projection...
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
