Question about Dishwashers
Hello. I have a blomberg dishwasher. now it has an error : call service and we found that the bottom of it,on the floor is watery. what is the problem??? what we can do??
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: blomberg dishwasher dw14110 i got wter
Look under the sink where the drain hose from the dishwasher hooks up and make sure the hose dont just drop down and it goes up higher than the drain pipe and then down to the dishwasher ,, water is running back down the drain back into the dishwasher.
Most always keep some water in the tub but if there is water every time then the pump is not pump all the water out ,, pull the d/w drain hose off under the sink and hold it into a bucket and run the d/w in drain mode and if all the water drains from the d/w then you have a house drain problem and need a plumber and if not then you will need a new pump and this is something you will need a tech to come out on.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 21, 2010
SOURCE: Water is settled at the bottom. Filters have been ...
My dishwasher did the same thing after a cycle was interrupted. Try putting your hand under the handle and firmly pushing against the top center of the door so the actuation of the switch is completed (the switch is in the door on my model and I suspect the actuator's travel is not getting completed).
Worked for me after pushing every combination of buttons and waiting for anything to happen.
PS: I pressed the START/CANCEL button during power up and the display showed IF for 5 secs then showed alternating H/H6. Anyone know what that means?
Posted on Dec 25, 2010
Bloomberg freezer error code e9
Error Code E9 ' Appliance Video
www.appliancevideo.com/repair-help/question/error-code-e9
The unit keeps getting a low water error and everything I could think of checks out: inlet valves, w. ... Error Code E9 ' Appliance Video .... Ice on bottom of freezer
Jul 23, 2015 | Blomberg BRFB1150 | 11.7 cu. ft....
I have a Blomberg GVN9380 dish washer which is suddenly not working and giving the error 1F. What can we do to fix this please?
Go to repairclinic.com and use the self help section. Enter your model number first to get specific trouble shooting info for your model.
May 13, 2015 | Blomberg Dishwashers
Dishwasher is powered on but and making normal start up noise but no water is entering the dishwasher and not beginning the wash cycle
My Dishwasher is a Blomberg DWT 25200 SSWS. It had the same problem. It powers up but no water enters in it and the clock didn't advance. This is what I did to fix it.
You can display the error code by powering off the dishwasher then pressing the 'Program' and 'Half Load' buttons at the same time then power on the dishwasher. This will show an error on the screen. My error was E:1.
The problem was a disconnected blue hose at the bottom of it.
This is the overflow detector.
This little board has a 12 Volt relay that activates the main water valve which is a 120 VAC valve. There was nothing wrong with it.
This plate is at the bottom of the dishwasher to hold the water that spills.
May 07, 2015 | Blomberg Dishwashers
How to get **** off of the bottom of the dishwasher
There are many sites telling how to clean a dishwasher.
Just search for "How to clean a dishwasher."
Here is one link.
Your Dishwasher is FilthyHere How to Clean It
Aug 03, 2014 | Blomberg Dishwashers
My Blomberg dishwasher wont stop drain cycle
A common cause of this condition results from water in the base pan. This may result from a leak in the dishwasher or the drain hose (to the sink drain) backing up. First check the base pan (the very bottom assembly that all other components are mounted within) for any moisture - this can be difficult as there are only narrow openings between the tank and the base pan; a mirror can help or you might have to pull the unit out from the cabinet to access the sides. If there is moisture in the pan this problem must be corrected as the unit is just trying to protect against water damage from a leak. If the base pan assembly is dry, look at the float assembly (behind the water fill valve) as insects or rodents can sometimes interfere with the proper operation of this sensor. That causes the control to think there is a water leak. When this fault occurs everything is turned off and the drain pump runs continuously to eliminate any water from inside the dishwasher.
Apr 06, 2013 | Blomberg DWT14210
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
Our Blomberg DW-35100 is not draining. We did have a service person in who fixed the problem temporarily. He took the bottom plate off the tub and told us water was present there which raised some float,...
If your Blomberg dishwasher will not drain, it might be the same problem that I had. The filter is a bad design and it lets a lot of debris through. The hose from the dishwasher to the main drain is very small and it gets plugged. Under the sink, loosen the clamps around the hose going into the main drain and take off the dishwasher hose. I use a screwdriver to push the debris through the small hose (that is attached to the big main drain hose) into the big one where it will be carried away. Then I turn on the dishwasher, hold the start button of the dishwasher for three seconds and shut the door. It drains like magic. The first time I did this, it took two hours to figure it out and now I can do it in three minutes. I am going to write to Blomberg now and see about this terrible filter system!
Feb 12, 2011 | Blomberg 35100 24 in Builtin Dishwasher
Washer
You bet, the tub seal is out and also the clutch and drive tub assemblies need to be replaced because like a drum brake oil has contaminated the pads. Did you notice that if you open the lid while spinning that it takes longer than seven seconds for the basket to stop? See the pic below, you need parts 1 and 5 plus the tub seal and center post seal.
Sep 30, 2008 | Washing Machines
Dishwashers Logo
Top Dishwashers Experts
