My tl wn 7200nd TP-Link wifi device is not working on windows8. How can i fix this problem?
It is not working on windows 8 operating system due to any driver problem. windows does not shows wireless networks and does not connect to any wifi network.
drlalitv
  • 488 Answers
SOURCE: secure my network (wi fi TP-LINK) model no: TL-WA601G
two options:one is to run the cd that came with the router and follow the wizard and configure the network..other is to log into the router by typing 192.168.1.1. or 192.168.1.1. in the browser or if any IP address mentioned on the body of the router please use that..enter the login and password..usally admin and admin by default..go to the wireless security and set it up..u can also change the network name etc..there will be a provision to backup the settings too..please don't settings that u don't know about as they can misconfigure your network..hope it helps!
Posted on Nov 07, 2008
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
SOURCE: I cannot connect my xbox 360 to my tp link router(tl-wr6145)
change your country to china or canada on your settings
put your disk in go online and change your region to china or canada
Posted on Apr 07, 2009
govinda123
  • 2263 Answers
SOURCE: cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
Posted on Feb 01, 2010
  • 66 Answers
SOURCE: We just bought a new emachine, Acer E627, with
WPA is not very stable and I have seen many problems with this. Simply change router setting to be configured with WEP and use a good strong password in hex 0-9 and a-f . WPA is horrible any way, and who the heck is gonna sit out side your home to hack it? It is not a WIN 7 problem but more like aging encryption.
Posted on Feb 11, 2010
I cant seems to be able forward ports on my TP-Link WR841N Router to view my cameras remotely. Pls can somebody help me with a solution. what should i do?
First, you need to know what's IP of Router and your Camera (or DVR). Then browse to IP of Router and setting up NAT port (or port redirect. If cannot you can give me your Skype, I will help you more then here.
Jun 06, 2015 | TP-Link Technologies TP-Link TL-WR841N...
Can i add a wireless dual band usb adaptor for wifi to my xp home edition
yes. System Requirements OS: Windows 7(32/64bits), Windows Vista(32/64bits), Windows XP(32/64bits)
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704135
Oct 15, 2014 | TP-LINK Computers & Internet
TP-LINK TL-WN727N
I just purchased TL-WN727N and noticed that is about 40 percent weaker reception signal than my other two usb wlan adapter(D-link DWL-G122 and Airlive WN-200USB),so I think it's product limit.
Oct 26, 2012 | TP-LINK TL-WN727N , 150Mbps Wireless Lite...
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
I bought a TP-LINK TLWN7200ND adapter, but it doesn't detect any 802.11b/g router, even with the latest version fo the driver for Windows XP. How can I fix it? Does only work with TP-LINK 802.11n...
i have used a similar adapter on windows 7 as well as on ubuntu 10.04 (linux), and it detects it upon restart without any external drivers.
try on a system with any of these to confirm that the adapter is good. this could be a hardware fault.
also, try changing the card slot as there could be a problem with the slot.
if it works fine on these, then make sure you are using the correct drivers (the ones exactly for this device and not for another similar device)
Jun 08, 2011 | TP-LINK TPLink Tp link Tl wn7200nd 150mbps...
Open Questions:
Computers & Internet Logo
250 people viewed this question
David Payne
David Payne
