Question about BMW 2002 325 i
Belt broke a small belt connected to the fan broke, antifreeze leaked out everywhere, but the car didn't overheat. The check engine light came on. Fan is loose. How do I figure out which belt it was and how to replace it?
  • 4 Answers
You need to go to a car shop
Posted on Dec 11, 2012
  • Page Neville
    Page Neville Dec 11, 2012
    Lol! I know that is always a solution. Do you know how I can get a diagram of the different belts?
What cause of overheat from engine
an engine will overheat if the rad cooling fan is not working, this will have to be check to see if its the fan motor, the fan relay. low coolant level, top up coolant check for leaks. could be head gasket problem, bad water pump(impeller worn).
Aug 08, 2014 | Daihatsu Charade Cars & Trucks
Antifreeze Leak - '99 Chrysler 300M
what you do is go to a radiator specialist shop and have a coolant pressure test done
most probably a cracked top plastic tank
as for the leak at the back , it could be a rusty welsh plug but the pressure test will also show that
Mar 03, 2017 | 1999 Chrysler 300M
Car overheats, losing antifreeze...the overflow coolant reservoir leaks out onto the ground when I try to put antifreeze in there - so could this cause my car to overheat? I have had the antifreeze drained...
Hello, if your car has a blown head gasket and exhaust is entering the coolant system, it will continue to run hot until it is repaired. Using pure antifreeze will make it worse. It should be at least 1/2 water. If the coolant reservoir didn't leak you could probably drive a few more miles, but not many, before it overheats again. All that is doing is giving you a little more capacity. If you continue to run the engine hot you are going to do more serious damage to it.
I suggest you have the head gasket replaced. That stuff you put in there seldom works, and if it does work, it's only temporary.
I hope this helps.
Sep 17, 2011 | 1985 Honda Civic
My car's fanbelt broken on high speed and I saw the temperature raised so I stopped immediately before it could overheat but then I saw the water leak out.After replacing the fanbelt I put Water in again...
You did well by shutting down quickly.
Why did the water come out when you stopped after the fan belt broke???
Residual engine heat. The engine has fiery explosions going on in the cylinders. Very hot.
Antifreeze flowing through the water jackets of the engine carry this heat away. Fan belt breaks, water pump stops pumping this very hot coolant away, engine temp goes up.
Thus the coolant temp rises enough to boil and push the coolant past the pressurized radiator cap out the overflow onto the ground.
I would recommend a fifty fifty blend of antifreeze and water for coolant. It just cools better.
Not seeing any leaks is very good. Smart thinking on your part saved you money.
Wayne
Feb 13, 2011 | Mazda MX-6 Cars & Trucks
The fan belt came loose while driving and then water started to flow from under the engine does this mean the head gasket might of gone
if the fan is on water pump, then I would say its a bad water pump, look under pump while running and if its bad it will leak from bottom. it may be a hose under car as the belt broke. and it over heated if water pump was not working.
Aug 14, 2010 | 1999 BMW 318 ti
Overheats and engine check light comes on
could be anything from a blocked rad ,sticky thermostat ,to a head gasket
Mar 17, 2010 | 2000 Hyundai Elantra
1998 Pontiac Bonneville overheat
no the computers only job is too turn on the fans. check for enough antifreeze check for leaks. these cars are known for leaks. if the water pump is broke internally it will overheat with in minutes, or if the thermostat is stuck it will overheat too.
Aug 04, 2009 | 1998 Pontiac Bonneville
A belt snapped, leaked antifreeze and no power steering
If it was the timing belt, the car would have quit right then and there.
It's the belt that drives the fan, water pump and power steering.
Probably what they call the serpintine belt.
Apr 16, 2009 | Ford Mustang Cars & Trucks
Car overheated and now leaks coolant
Thats not a good sign. When a engine overheads, the heads tend to warp, especially aluminum heads.It could be something as simple as a hose or waterpump leaking, but because its associated with an overheat condition, I suspect a warped head. Most garages have a pressure tester where they can pressurize your coolant system and check for leaks without the engine running.
Jan 16, 2009 | 1989 Chevrolet Cavalier
BMW 2002 325 i Logo
Top BMW Heating & Cooling Experts
cwradio73
richie46
Gil Shultz
Are you a BMW Heating and Cooling Expert? Answer questions, earn points and help others
