Question about Electronics - Others
Ttanscaned pen drive problem
I Have transcaned (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk)
When I try to format Pen drive Show message (There is no disk in drive G)
G Drive Right click And go properties Show 0byets
Pls solve the problem
Regards,
Prashant
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show message (Pls Insert Disk) When I try to format Pen drive Show message (There is no disk in drive G) G Drive Right click And go properties Show 0byets Pls solve the problem Regards, Prashant
Posted on Nov 16, 2011
    New Friend:
Hello, you just have formatted your pen drive without extracting data inside at first? Why do you have to format that USB pen drive without rescuing data out? Is it asking you to format and its file system become RAW weirdly? OK! No matter why you have to format that USB drive, the data stored inside after format often will not really be completely wiped.
Without fresh data to overwritten it all there, you do get chances to recover lost from this formatted pen drive with Pen drive RAW file system recovery software which often will deeply scan your assigned flash drive and take all possible recoverable stuffs back.
Therefore, do not give up and go search for related data recovery software to go on.
Hope you can make drive data backups well before any format.
Posted on Nov 10, 2015
    Scholar:
  • 77 Answers
Click Start -> Run. Then type miskmgmt.msc and press Enter.
See if the pen drive is listed along with your hard drives. If yes and it says anything other than "Healthy", then the computer recognis the drive but the partition(s) is not accessible or is corrupted.
Try plugging in to the back side USB port if you are trying this in the front panel USB.
If that also doesn't work, plug your drive in to another computer you might have access to.
If still no luck then ...
This is a known problem with Transcend pen drives I have seen before. You can get access to data if you get some disk recovery utilities like pen drive disk doctor etc.
Get the free version of this tool from
http://www.deaddiskdoctor.com/
and save the files to some folder on the hard disk. Then format the pen drive and copy the data  back.
HTH,
Deboo
Posted on Jan 18, 2009
Whenever i insert my pen drive and try to open it it says insert drive.its a 8gb transcend pendrive unable to open or format it. It says insert disk.
Do one thing download the transsend s/w from website and try to formate the pendrive
Otherwise instal the USBDISK andi virus and delete the some file from that pendrive.
Nov 17, 2010 | Computers & Internet
I,am,having PNY 8GB pendrive. Whenever, I, am attaching this pen drive to PC, and tries to open the message shows Plese insert the disk. Could you suggest some solution for this problem?
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jul 02, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
PEN DRIVE ERROR
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
Feb 03, 2009 | Transcend (589307) Media
Pen drive is not working properly
try to replace the unit.
it is possibly faulty.
also you should note that pen disks are not as reliable as hard drives.
Jan 23, 2009 | Electronics - Others
Pendrive problem
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
Oct 24, 2008 | Transcend (589307) Media
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Problem detecting transcend pendrive
On opening my pen drive it displays "Pl insert a disk in drive G
Feb 16, 2008 | Transcend T.sonic 612 MP3 Player
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
Electronics - Others Logo
674 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
