Question about Refrigerators
My mini fridge turns on, but is does not cool. When I open the door there is also a weird odor being produced. The compressor (I guess it is, the ball thing in the back) gets hot and I hear buzzing in the fridge but its not getting cold inside. :(
    Problem Solver:
  • 13 Answers
THERE IS A FREON LEAK OR YOU ARE COMPLETELY OUT OF FREON
Freon is a coolant/refrigerant used in A/C's or refrigerators to cool the air
Posted on Dec 11, 2012
  • vbiteng
    vbiteng Dec 11, 2012
    Is that pretty inexpensive to fix?
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
SOURCE: Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Feb 28, 2009
MNTECH
  • 1543 Answers
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
Posted on Apr 11, 2009
erpaalai
  • 999 Answers
SOURCE: Mini Fridge not working MCBR445
Compressor is in a locked up/ no start condition. the overload cools enough to reset and tries to start it again and kicks out on amp draw, then the whole cycle starts over again.
Eric
Posted on Jul 16, 2009
Fan and compressor running but fridge not cooling
Your defrozed cycle seems to be not working. Means there can be problem with heater , timer or defrzed board or defrozed thermostat. You have to open panel from coil to diagnosed this.
Mar 03, 2014 | GE GSH25JFR Side by Side Refrigerator
My fridge(& freezer) started giving off a bad burnt odor then stopped cooling (amana 25 cubic/mod #afd2535fes). any suggestions as to what it might be?
You said it stopped cooling, does the compressor kick on, or is it dead? Is the condenser fan operating (the one that blows across the condenser grill by the compressor)?
Is your condenser grill clean? What indications are you getting specifically?
Jul 15, 2011 | Amana 25" Cu Ft French Doors Bottom...
We have a terrible odor from fridge side. Cleaned it 3 times..found nothing and odor persists Any suggestion? No odors when doors are closed
What does it smell like? Burnt plastic , mold , rotten food? Check gaskets and temp in fridge, food could be spoiling. It is tough to get serious odors out of fridges. Bleach, vinegar are good for killing odors. Check manufactures recommendations.
Apr 14, 2011 | Viking 42 in Built In Professional...
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
My GE refrigerator is leaking cold air at the wires coming out from the back of the refrigerator. The frame around this hole is cold. Is there a leak inside the refrigerator? What can I do to fix this...
refrigerant could leak inside the unit, it could smell bad if the compressor had a burnout
refrigerant carries oil troughout the system and back to the compressor
if the compressor had a burnout, the oil would turn acidic creating an odor if there is a leak
personally I would check what's inside, open a box of baking soda and see if this eliminates the odor
if your fridge quits cooling, you've got a leak
Sep 17, 2009 | Refrigerators
Odor in the fridge after the compressor broke down
All refridgerators will develop an odor whenever they are turned off, or the temperature gets too warm. The reason for this is that the small microbes from the various food stored in the fridge will start to grow some bacteria which will make the fridge smell.
You should empty the fridge and freezer, turn it off and clean the inside with a solution of white vinegar and water (50/50 mix) and wipe all the surfaces and dry it off. Also clean out all the bins and shelfs and compartments. Then leave the doors propped open for a few hours to remove as much moisture as possible until it's dry and you can confirm there is no more smell.
Put back all the shelfs and such and turn the fridge back on and you should be fine. Hope you find this Very Helpful and best regards!
Sep 09, 2009 | Kenmore Refrigerators
I have a kenmore elite model 59676539500 and is not blowing cold
hello, that would be my first guess can you hear the compressor trying to kick on at all ? how old is your kenmore ? if theres no cooling anywere and out of the blue it just stoped cooling then your right with the compressor
Apr 01, 2009 | Refrigerators
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
