Question about Panasonic KX-TG2313 Cordless Phone
Handset lights up, but does not work, only beeps when you touch any key
Cordless phone Panasonic KX-TG2313: have had for about a year, and handset now only lights up. Cannot call out or receive calls and when I press any buttons, there is three beeps. Does this mean the battery needs to be replaced or is the phone just broken. Don't want to waste money on battery if the phone is just broken. Thanks for your help
  • Anonymous Feb 07, 2008
    My telephone is already 3 years old. I’ve had the same problem already 2x. I believe this is our telecommunication problem… not the unit.
    The solution which helps me is very simple: disconnect and unplug from the power. Don’t us it for around one day and then set it up again.
    It works for me. You can try.
First, hold down the "handset locator" button on the base, until the "charge" light flashes. then, hold down the flash/call waiting button until the LCD says "handset registering." if after about a minute it says "error!!!" then try again. that is what the instuctional booklet says. i have not done this successfully yet as i have the same problem, but this is apparently how you fix it.
Posted on Dec 22, 2007
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
I want to make my phone touch tone
I presume you want to use tone dialling..If that is the case the solution should be same as my phone.. Press Menu then scroll using up/down arrow key to "Initial setting" and press(soft key) Select, then scroll to "set tel line" press(soft key) select, then scroll to "Set Dial mode" press(soft key) Select, then scroll to "Tone" , then press(soft key) Save then press Off button.**This is done via handset**Soft keys are the ones under screen*** I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-TG2313 Cordless Phone
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
Had the phone unstall for a while and reconnected it. Charge the battery and when I try to make a call it says move closeer to the base unit when I'm standing right next to it.
In my Panasonic, there are instructions to re-register the handset. Basically, it involves going to register on the handset and then pressing the handset locator on the base until the light flashes, then press OK on the handset and let them find each other.
Carl
Feb 04, 2011 | Panasonic KX-TG2313 Cordless Phone
I have a panasonic KX-TG2336S cordless phone and when you try to make a call the handset displays "no link to base". Can this be fixed or is the phone shot?
Just in case you don't have a manual
http://service.us.panasonic.com/OPERMANPDF/KXTG2336.PDF
Page 55 lists your trouble and gets you to page 49. You take the bandset and base, press the locator button on the base and then press the flash/recall button on the handset until Handset Registering appears on the display. If it beeps one time, wait 20 seconds and it should register. If it beeps 3 times, keep trying.
Carl
Jan 18, 2009 | Panasonic KX-TG2336S Cordless Phone
Ringer not working
On the base press the volume up [^] key. Repeat pressing to get higher volume. Press volume down [V] for reducing the volume. Press and hold volume down for two seconds to turn ringer off. On the handset, you can use the menu to turn ringer on and off.
Nov 19, 2008 | Panasonic KX-TG2313 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Panasonic KX-TG2313 Cordless Phone Logo
261 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
