Question about Whirlpool Duet GHW9150P Front Load Washer
How to set delay wash on a whirlpool duet washer
How do I get the delay start to work?
duby1990
  • 367 Answers
SOURCE: How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Posted on Nov 19, 2008
aborcass
  • 2651 Answers
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Posted on Nov 20, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
  • 1314 Answers
SOURCE: whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Posted on Feb 12, 2009
  • 126 Answers
SOURCE: whirlpool duet washe always out of balance
remove lower front panel and you should see shocks on lh/rh of tub. probably one broken ,replace both. Hope this helps, please rate my solution :)
Posted on Jun 25, 2009
I have a whirlpool duet steam front loading washing machine model # WFW9600TA01. recently when my wife starts a load of laundry at night when she wakes up in the morning the washer is still turning at a...
I would assume the load in the washer is a small load and the washer has a difficult time adjusting the load to spin. I would push pause, wait for the system to unlock the washer. Check the load for how much water in the garments. If heavy, the unit has a unbalance issue, just try to continue the load. If the clothes are light than unload the washer into the dryer. Was the unit ran on delay? This may be a non issue if the unit ran on a delay and just never finished yet.
Give those a try and get back to me, I and interested in the status.
Aug 21, 2011 | Whirlpool Washing Machines
Will only wash on delay wash
Whirlpool has a great help section at there website
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer has no power!
call whirlpool, sounds as if you have a faulty electronic control board( power supply board) warranty issue, non need for you to get involved with the repairing of this
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Paused washer will not restart
check that machine has not gone onto time delay , re-set if it has
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Safety lockout on
use the control key...
just kidding
there's a delay in that cycle..You MUST wait until it's clear..otherwise, you may find yourself engaged in a 'hot' situation.
Feb 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Delay Start not working
your delay switch should be separate to your main board it will be faulty the delay switch and should be cheaper than replacing your washer there is nothing you can do if this part is faulty sorry for the bad news m8 it is only a small circuit switch to replace
Aug 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
