Question about Soleus HGW-203 Micathermic Infra-Red Baseboard Heater
Back up electric heater required.
Please would you advise.
I have a living room of 40 sq mts with underfloor heating. The maximum teperature acheivable is 21 c. I need an additional minimum 2c for this room to feel comfortable. There is a lot of window space so I beleive this is the reason for low heat. I would like the best portable electric solution.I was thinking convector/micathermic k/w? Please would you help. Thank you, Steve Dew.
    Problem Solver:
  • 5 Answers
A bit late for you probably Steve, but other browsers might be interested...
Micathermics are faster to warm up the room than other resistive heaters, but otherwise they're no more efficient - so it depends whether you feel that the fast warm up is worth the extra money that the micathermic would cost.
If your ceiling is well insulated (including over the wall plates at the top of the internal walls) then the large windows are very likely the reason that your underfloor heating can't get the heat high enough. Have you considered double glazing? 3M have a very cheap, disposable window insulation kit that you could put on for a cold season to see if it's worth putting in some more permanent double glazing (and in fact that kit will probably last 2 or 3 cold seasons if you just leave it up).
The heater power (kW) required to get that extra 2 degC depends on how well the room is insulated. Your best bet would be to find out how much kW your underfloor heating is putting out and how much degC it is warming up the room, then keep the same proportions to work out how much extra kW you need.
Posted on Jul 02, 2010
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little boxes.so in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
Tip
Underfloor Radiant Heating for Your New Sunroom
You want to add a brand new sunroom onto your existing house. The problem is that you are not sure how to heat it. Electric heating with baseboard heaters will spoil the look that you want from your new room. Hot water baseboard is going to present all types of problems getting hooked in to the existing system and piping it. And, if you have hot air heating system then you will have the problem of getting ductwork to the room. There is another way to heat this room easily and efficiently.
Radiant heating has been one of the most comfortable and efficient ways for heating for many years. The problem has been in the past to find a good heating source for small radiant floors that will be affordable, effective and efficient.
This problem has been solved now, with the availability of small new electric combination heater- circulator units. These units use small electric heating elements together with a small circulator pump to give you a all in one heating source and circulator pump.
Now you just have to lay your tubing in the floor of the room you are adding on to your house. Then you run that tubing into your existing basement or other room in your house. The tubing and the electric are attached to the heating unit. Then, wire a thermostat to the unit, and you are now ready to make heat. This really makes heating a new addition room very inexpensive and easy to do.
The greatest thing about using this type of heating system is that most average do-it-yourself types can do this. All that is needed is a basic knowledge of plumbing and electric.
If you are thinking of building that little add-on and are worried about how you will heat it, think about using radiant floor heat and a small electric heater-circulator to do your project.
on Dec 05, 2009 | Heating & Cooling
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Heat for a 3 seasons room
single pane glass is not thermally efficient as the glass transfers heat or cold
double glazing with a air space between is more efficient and will require less power to keep the temp setting
before you do anything , talk with a thermal engineer or you could be wasting money by doing what you suggest incorrectly
Apr 18, 2017 | Heating & Cooling
How much ventilation is needed for operation in 250 sq ft room?
A lot of variables in the question you asked. First, you need to convert your square footage to cubic footage. To do that multiply your square footage by your ceiling height. Assuming you have the standard 8' ceilings, your cubic footage is 2000 cubic feet. Also, what is the maximum BTU Output of your heater. Will the heater be the only heat source?
Now, how air tight is this room: fair, average, excellent? Also, is there a door opening(s) to the rest of the interior of the house? Will the door(s) remain opening during times the heater is in operation? Is this room, a bedroom? If it is a bedroom, the maximum BTU Output can not exceed 10,000 BTU's.
If it's not a bedroom and the maximum BTU Output range does not exceed 20,000 BTU's, you should be fine, as long as this room opens into the rest of the house and the door is left open. Higher than 20,000 BTU's will cause a problem.
Keep in mind, these vent-free heaters use interior air for combustion and as far as BTU Output is concerned, more is not better. Because, you are capturing all the heat. Safe placement of the heater is very important. Always keep combustible items at least 3' from the front of the heater. And never near draperies. The back of the heater should be a minimum of 12" off the wall.
Vent-free gas appliances are very safe when used as the manufacturer intended/specified. However, they are not maintenance free and should be cleaned and serviced at least once a year. Not only to maintain proper operation and efficiency, but equally as important SAFETY.
Feb 01, 2011 | Dyna-Glo Double Tag-a-long Heater
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Amps needed to run a central air unit
Central air requires a 2 pole 30 amp breaker or fuse. You may be able to get by without it but 200 amp service is recommended.
Jan 31, 2009 | Weather King 12AJA4801AH Air Conditioner
High Altitude Electric Heaters
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Dec 26, 2007 | Dayton Electric Heater
Holmes bh3955 or holmes hh3690
figure out your square foot requirements - multiply 16 X 20 to get 320 sq ft. Find a heat formula to consider windows and doors and known insulation in the walls. this will give you BTu output required to raise the inside air from 68 degrees (norm) to 72 degrees.
Dec 06, 2007 | Holmes Products BH3955-U Bionaire Utility...
Heating & Cooling Logo
162 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
