Question about Jura Capresso Impressa F9 Espresso Machine
SOURCE: malfunction code 8 on Jura Impressa s8
To fix this problem you need to clean the layers and layers of coffee mud off the plates that dispense the spent grounds into the hopper. My suggestion is to do this major muck cleaning before you even put the cleaning tablet in.
Get a flashlight and pull the trays out and have a look at the mechanism that dumps into the hopper. You will see the layers of gunk that need to be scraped off. Easiest thing to get in there is a finger to start, then place it next to your sink and clean it with a water jet from your kitchen faucet, provided your faucet will allow you to do that. Let the runoff go into the sink of course. After you get it cleaned up, then put the machine through the cleaning cycle.
If you can't get the problem solved, the fix is a flat $200 from Capresso.
Call the number above to get set up with a service shipment, done in PA.
Devin in Ohio
Posted on Nov 25, 2008
SOURCE: jura impressa f9 malfunction 8 i need help whats
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Posted on Jul 09, 2009
SOURCE: error 6 for jura impressa z 5 ?
Error 6 means that the automatic ceramic valve having a problem reaching the right position. This is usually related to the main electronic board and there is a chance that this needs to be changed. There could be a possibility that the multivalve is broken, but if you can hear it turning when you start up the machine, it`s probably ok. Contact your dealer for service, or call Jura hotline for your local servicecenter; +41 062 389 82 33
Posted on Oct 06, 2009
SOURCE: My Jura Impressa xs90 keeps stating fill system,
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Posted on Oct 16, 2009
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
Dec 29, 2016 | Jura Capresso Coffee Makers & Espresso...
Oct 13, 2016 | Capresso Jura Impressa J9 One Touch...
Jul 03, 2016 | Jura Capresso Impressa Coffee Makers &...
Jan 14, 2016 | Coffee Makers & Espresso Machines
Nov 25, 2015 | Capresso Jura Impressa J9 One Touch...
Nov 16, 2014 | Jura Impressa F50 Classic Automatic Coffee...
May 27, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Dec 15, 2013 | Jura Impressa J9 One-Touch TFT Espresso...
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Feb 18, 2008 | Jura Capresso Impressa S90 Espresso...
