Question about Dishwashers
My Samsung Dishwasher series DMR77XXX is showing a 9E code
2 Suggested Answers
  • 6 Answers
SOURCE: We have a samsung dmr77xxx dishwasher and it
Most 9E error codes are caused by a sticky float located on the LHS of the dishwasher. You can sometimes do a temporary 'fix' by 'thumping' the left panel inside the dishwasher (towards the bottom).
Posted on Oct 07, 2012
My dishwasher display 9E error what can I do?
Tell us the make and model number is the first thing you need to do.
Mar 21, 2017 | Dishwashers
Dishwasher starts and then stops with 9E flashing in window.
The 9E issue indicates a low water level in the dishwasher. Check your hoses. Make sure that no dishes flipped and filled with water. Make sure that the dishwasher is level. Next check if there is any debris blocking the water level (overflow) sensor. It's in a small square plastic box on the left side of the dishwasher. Pull the dishwasher forward and check for loose or damaged wires to the water level sensor.
If the wiring is good and the error persists, replace the sensor. Replace the wiring if it is damaged. If you add a comment with the model number, I may be able to point you to the replacement part. If your dishwasher is under warranty, contact Samsung for the repair.
I hope this helps.
Jul 04, 2016 | Samsung Dishwashers
Samsung dishwasher code 9E
Internet search "Samsung dishwasher 9e error code". Many videos to watch to show you how to fix the problem yourself.
Sep 05, 2015 | Samsung DMT800RHS Dishwasher
I have a 3 year old Samsung DMT800RFS dishwasher. It had a 9E error, so we changed the part on the side and replaced the interior gasket. Now we get a oE error and I can not enter Service Mode to re
I don't know if this is the same. However, on my washing machine I had to clear out the water trap at the bottom of the machine. I know I have to clean it out every 6 months to be on the safe side. This also helps the machine to not smell like old stagnate water and helps your clothing smell fresher with not having that water build up and sit. I found all strange things in all kinds of water overflow tubs.
Dec 20, 2014 | Samsung Dishwashers
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
Nov 06, 2014 | Samsung 800 Series DMT800RHW 24"...
Samsung dmt800rhs errorcode 9e
http://www.youtube.com/watch?v=HXHRPd8VisE The water level float switch needs to be cleaned. There is a micro switch on the assembly don't get the switch wet. This video will show you what to do.
May 06, 2014 | Samsung DMT800RHS Dishwasher
9E error code on dmt800rhs dishwasher
I also had the 9E error code on my Samsung dishwasher DMT800RHS mmodel. I had to call Samsung and the nearest authorized Samsung service representative came to my house last Tuesday, January 29, 2013. The cost of the call is $100 which really annoyed me off considering the dishwasher is only 1 1/2 years old. Two South Korean guys showed up and to fix the problem just press down on the Heavy, Delicate and Power button at the same time for a few seconds and a menu will appear on the top left hand corner of the panel. Scroll down the menu by pressing the Normal button until you reach "FT" and the dishwasher will automatically fill up and then autimatically drain. If it does not drain then scroll down to "S" and the dishwasher will drain. Thsi should get rid of the 9E error message and your dishwasher will work fine but if not you have to repeat the procedure maybe 2 or 3 times until the 9E error message disappears. If you constantly get the 9E error message then you may need to replace the part which is about $60. The part is extremely sensitive to either hard water or food particles which is why the 9E error message appears. Therefore, scrape your dishes thoroughly so the food particles are minimized and the sensor does not go off which causes the 9E error message.
Nov 21, 2012 | Samsung DMT800RHS Semi-Integrated...
We have a samsung dmr77xxx dishwasher and it keeps getting a 9E error and stopping> what is causing this error? thank you
Aug 23, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    Dishwashers Logo
    41 people viewed this question
    Top Dishwashers Experts
