Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
I have a toshiba 46h84 the picture is very light and lines all across the screen what could this be?
Sound works fine but even if i hook up the hdmi their is a slight picture but other than that just lines
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Possible screen controls in the set are up too high---if you turn picture and brightness to zero does the screen get full black?
screens set too high would give diagonal faint trace lines in the picture.
These sets also should get a annual cleaning of the lens and sometimes the mirror inside= if this is the case the picture will usually look darker and dull ----this will not affect lines in picture.
the lens are easy to clean but other actions depend on what your response is to the above information.
Posted on Dec 11, 2012
techman
  • 3130 Answers
SOURCE: Toshiba 46H84 HDMI Card Replacement
The only thing I could recommend is to return the board and get the right board. open the set and get the part number on the board itself. You cannot modify a set to work things it was not designed for without reprogramming the microprocessor. Good Luck
Posted on Jun 26, 2007
SOURCE: Vertical lines across the screen
I now have the same problem. Lines are on the left side of the screen almost have way across the screen, with a thicker line int he middle which is the same length. It started last week and stopped after fiddling with it. Now it comes on fine then about 5 min . in the lines appear. I have had the tv for 1.75 years myself and have had to deal with bulbs popping numerous times (3). Was this the same as yours? Did solutions work? Please do tell.
Posted on Dec 02, 2007
techman007
  • 1112 Answers
SOURCE: I have a 3 years
Have the input signal board replaced. Might try also replacing the digital board assembly.
Posted on Oct 24, 2009
SOURCE: lines on my toshiba model 46h84 projection tv
I have the same issue with mine which started a couple of months ago and has only gotten worse. I've been googling this and found that it could be the convergence module(s), apparently there are 1-3 of them and ALL of them should be replaced. I'm not sure on a cost, but I'm guessing it won't be cheap. I think we are just going to get a new tv, with the prices for LCD's coming down this will probably be a cheaper option. Good Luck :)
Posted on Mar 24, 2010
  • 336 Answers
SOURCE: why is my toshiba 46h84 picture getting darker
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 30000 hrs,1-2yrs it could be time to replace the lamp.The lamp you need is TB25-LMP you can find it here;http://www.discount-merchant.com/Toshiba-TB25-23311083-Lamp-Bulb-Only-p/toshiba_tb25_23311083_lamp.htm?Click=48173 .Have a blessed one!
Posted on Apr 16, 2010
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Lines on my toshiba model 46h84 projection tv has lines on screen until it warms up What could be causing thi. Once it warms up the picture is fine. which takes about 10 minutes
Mar 23, 2010 | Toshiba 46H84 46" Rear Projection...
Sirs: We were just changing channels and the
THE projection bulb is blown if no sound tv probably broken
Jul 31, 2009 | Toshiba 46H84 46" Rear Projection...
No picture but sound on Toshiba 46h84
If you feel comfortable enough, you can try replacing the pico fuses on the power supply board. Test them with a multi meter very carefully.. these sets have up to 5000 volts and care should be taken, even by a professional with the back panel removed.
Jun 13, 2009 | Toshiba 46H84 46" Rear Projection...
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Tv picture
Does The line run vertcaly or horizontaly? Do you have a manual so I can help you repair your set. If not go to this link they have your manual there . Plus I am one of their techs and can assist you. Hope this helps. http://servicemanuals.vstore.ca/
Jan 11, 2008 | Toshiba 46H84 46" Rear Projection...
Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Oct 31, 2007 | Toshiba 46H84 46" Rear Projection...
Jun 26, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
