Question about RIM BlackBerry Curve 8310 Smartphone
Can't open handheld key
I use blackberry 8310 t.mobile
I can hear peole on my phone but they can't hear me
Posted on Feb 22, 2009
  • rainmanj1 Feb 22, 2009
    I can hear people but they can hear me whats wrong?
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...
Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry Curve 8310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
How to rest a blackberry 8310
If you go to Settings>Options>Security Options>General Settings and then press the menu button to the left of the trackball, you should see Wipe Handheld as an option in the menu. This will wipe all data from the handheld and will, for the most part, restore the handheld to the factory settings. If you are/were set up on a BES, it won't remove the IT Policy.
Feb 23, 2012 | RIM BlackBerry Curve 8310 Smartphone
I have no signal on my Blackberry 8330 Curve. I have reset it, taken the battery out, as well as the sim card but the signal still has an "x".
make sure it is compatible with your carrier. T-mobile won't work with AT&T and visa versa. All Blackberry handhelds are carrier specific
Aug 12, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
I need to remove my Email accounts from my 8310 prior to selling this BB.
You will want to do a factory reset of your phone. This will clear it of any user information you had put on your phone, and place it in the condition when you first bought the phone.
WARNING: Proceed with caution. A factory reset will result in the loss of ALL user data. It is recommended to perform a backup of the RIM BlackBerry data.
  • Scroll to and select the Settings icon (to select push the trackball in).
  • Scroll to and select the Options icon.
  • Scroll to and select Security Options.
  • Scroll to and select General Settings.
  • Press the Menu key , then select Wipe Handheld.
  • The device is going to confirm that the data will be erased. Select Continue.
  • Enter "blackberry" to confirm handheld wipe.
Jan 21, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
I have a BB curve 8310 and need a mep code for unlockit please send me...!!! please... thanksssss!!!!
If it is a network unlock code you need to contact you're service provider.
if it is a keypad unlock code kindly enter wrong password for 10 time's you're Handheld will get wiped off. Then it will ask for reset password, Enter the new password and remember that.
NOTE:- No data will be available when your Handheld is wiped off.
Nov 17, 2009 | RIM BlackBerry Pearl 8100
Blackberry 8310 no service
First, please download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Aug 19, 2009 | RIM BlackBerry Curve 8310 Smartphone
To reset and reformat my blackberry 8310
try this
To delete all user information go to:
Options > Security Options > General Settings > press Menu key > Wipe Handheld .
Aug 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry 8310 charges,but doesn't connect with pc.
it is not a hardware or a software issue it could be a problem with the UBS port on the handheld or on the laptop or it could be a problem with the USB cable.
Aug 01, 2009 | RIM BlackBerry Curve 8310 Smartphone
Screen saying uncaught exception:DSSMA invalid state(5); 23
Perform a hard reset of the BlackBerry smartphone.
1. Remove the Battery and Sim Card from your Handset and Re insert it.
If it's still the same problem.
Perform these steps : -
Take a Back Up of your Blackberry Smartphone
  1. Connect the BlackBerry device to the computer using a USB cable, and open the BlackBerry Desktop Manager.
  2. Ensure that the BlackBerry device is connected correctly. The word Connected should be displayed at the bottom of the BlackBerry Desktop Manager screen.
  3. Double-click on the Backup and Restore icon.
  4. In the Backup and Restore screen, click Backup.
  5. Choose a location where you wish to save your backup file.
  6. Give the backup file a new name or leave the default name in the File Name field.
  7. Click Save.
  8. The BlackBerry device has now been fully backed up.
  9. Back up will be in .ipd file format.
Then in your Handset perform these steps :-
1. Press Menu Key,
2.Select Option Icon in the Menu screen
3.Go to Security Options.
4.then Goto General settings
4.Press Menu key, you will get an option Wipe Handheld select it.
5.Type the password if you get a prompt, default Password "Blackberry"
6.you will get a confirmation message,Data will be Erased.
7.Click Continue.
8.It will start Wiping your Handheld.
9. Once Data is Erased,Handset will Automatically Restart.
To Restore the Data to your B Handheld
  3. Double-click on the Restore Tab.
  4. Navigate to the backup file you want to restore to your BlackBerry smartphone.
  5. Double-click the backup (.ipd) file.
Jul 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Memo on blackberry 8310
On 8310 the MemoPad may be located in the Applications folder on your Desktop. If you can not locate it, you should download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Jan 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
41 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
