Question about SATO CL408e Label Printer
Printing problem: The printer keeps giving an error message "ribbon end" ribbon is full?
2 Suggested Answers
SOURCE: Ribbon End
Try changing setup from thermal transfer to direct thermal
Posted on Jun 19, 2008
We have a Rimage Everest II S/N 06074034 model number. Requesting Transfer paper?? Problem states "Retransfer out"
Hello Spacheco763,
The serial number provided is a DLN5200. I am assuming you are using the Everest II printer with this autoloader.
I don't think the message you are saying is the full message, but I will attempt to help.
If you just changed the ribbon and are getting an error stating there still isn't any left, go into Printers and Faxes and right click on the Everest II. In the drop down menu, choose printing preferences. Click the utility tab and open the Status Monitor. Here you can reset the ribbon count and view the status of the printer and ribbons.
If it is giving you a upper or lower retransfer ribbon error, the sensors closest to the retransfer ribbon need to be cleaned.
If this does not fix your problem, it could be a possible hardware issue. The serial number you provided is not under a service contract and will be going end of service (EOS) very soon. If you would like discuss this, feel free to give our support team a call at 1-800-553-8312 (Option 2)
Dec 06, 2010 | Health & Beauty
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
2265+ ribbon error
The Ribbon can only be installed correctly as you have to lower a bar after to allow the printer to start if it was in incorrectly this arm would not lower and you would get no printing.
Instruction manual will explain better
http://www.softwaredriverdownload.com/download.php?file=964rxfbkkrZnRwOi8vZnRwLnRhbGx5Z2VuaWNvbS5jb20vcHViL2dlbmljb20vZG9jcy90YWxseS9zZXJpYWwvdDIyODAvMDYzMDUwYV9vbTIyNjVfZ2IucGRm
Dec 27, 2008 | Tally T2265 Dot Matrix Printer 917402
Error / Ribbon Jam/Broken
When you open and close the lid on this printer, it tries to realign the ribbon. If you are getting this error, I suggestion you Calibrate the print ribbon through the print driver printing preferences on the Calibrate tab.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
I keep getting message insert ribbon parameter card and below it resolve error to resume printing
The "ribbon parameter card" is a little chip that is delivered with every newly bought pack of ribbons. You need to insert this card in the fitting slot of the printer (at the backside I assume), and let the printer read the contents of the chip. Once finished, you can remove the card.
You need to follow this procedure for the printer to be able to work with the new ribbon. If you do not have the chip for that ribbon you can not use it.
Oct 12, 2008 | Office Equipment & Supplies
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
SATO CL408e Label Printer Logo
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
