Question about Micrografx Designer Technical Edition 4.1 Full Version for PC
Will Micrografx Designer Technical Edition 4.1 run on Windows Vista?
5 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: I have been using Micrografx Designer 3.1 in
The present Graphics DLLs are compatible with Designer 3.1 with
OLE (dated May 28, 1992). If you are running an older version of
Designer on the OWS and the drawing uses Designer fonts, displaying
the drawing would give a protect violation from DCP by
MGXLIB.DLL because the MGXFNT.DLL are not compatible.
You can replace the older version of the MGXFNT.DLL with a new
one. To do this, copy MGXFNT.JCI from the C:\FMS\BIN
directory to designer libraries directory (MGXLIBS) and change the
file extension to DLL (i.e., MGXFNT.DLL). By default, the MGXLIBS
directory is located under C:\WINDOWS; however, you should copy
the file in the same directory that is pointed to by the Libraries
parameter in the Micrografx section of the WIN.INI
(e.g., Libraries=C:\WINDOWS\MGXLIBS
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 25, 2011
muntejaya
  • 10421 Answers
SOURCE: how i can import picks.. when i try,i got only
Please re install the software then.
Regards, jay
Posted on Feb 26, 2011
SOURCE: Just installed Micrografx Picture Publisher
I had the same message trying vista. Windows 7 offers running older programs in XP or even Win 98 SE mode. That fixed the problem for me. Further I recommend running it as administrator. Hope it helps.
Walter
Posted on Apr 17, 2011
  • 12 Answers
SOURCE: ou je peut me procurer
Essayez e-bay. On ne peut pas le trouver chez amazon.
Posted on Aug 03, 2011
Need micrografx Graphic Suite upgrade for Windows 7
Micrografx was sold to Corel in 2009, who then released the program as Corel Designer 9. You can upgrade to X5, the latest version, here.
Oct 23, 2012 | Micrografx Abc Graphics Suite
I have been using Micrografx Designer 3.1 in Windows XP for several years now. Recently, however, I have discovered that I cannot add text to a drawing. When I attempt to do so, I get the following error...
I had the identical problem on a netbook whose OS was WinXP Lite. The solution that worked for me was to reinstall the OS, this time using the full WinXP. Thereafter no problem.
Micrografx Designer 3.1 remains an excellent drawing program that was designed for Win 3.1 but works fine under Win XP, but not Win 7.
Feb 23, 2011 | Micrografx Designer Power Pack 3.1 Full...
Just installed Micrografx Picture Publisher 10 from the original disc. When I try to run it, I get the following error Micrografx Picture Publisher Digital Camera Edition has stopped working It says...
Walter
Feb 04, 2011 | Micrografx Picture Publisher Digital...
I am getting an error stating "Designer has encountered a disk I/O error trying to access the file", while trying to open a dsf file. I am using micrografx for more than 2 years now and lately i...
Close Designer 9.
Open the folder containing the 'DSF' file.
Try to copy the file into a different folder, or onto a USB memory-stick.
Do you still get the same error-message?
If so, then the problem is that your disk-drive has a problem;
your problem is _not_ a problem with the Designer 9 software.
Your disk-drive could be "dying". Backup all your important files.
Consider replacing the disk-drive, before it COMPLETELY fails.
Jan 27, 2011 | Micrografx Designer 9 Full Version for PC
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
I am unable to open Micrografx Windows Draw 6. I used it for clip art but now it won't open.
Hello, I had the same problem. windows draw has been working for years under Windows XP then suddenly impossible. I think there is a conflict with others programs i installed.
I found THE solution after reading many topics on the net :
Install acrobat reader 4 on your system. Then run acrobat reader 4. Last, run Micrografx windows draw 6 while acrobat reader 4 is running on your system too.
Maybe it works with a more recent version of acrobat reader but i didn't try. Maybe this solution works also with windows draw 5 but i didn't try.
Enjoy
Jul 10, 2009 | Micrografx Windows Draw Graphics & Print...
Micrografx Picture Publisher 8 not working with my Vista
I solved it!
The software installs OK.
After installation, reboot.
When you need to open the program, right-click on the Micrografx icon and select Run as Administrator. A yellow window pops up saying "An unidentified program want access to your computer," with pp80.exe as "Unidentified program" - that is actually Micrografx Pictures. Click "Allow." The program runs normally. The only caviat is that you will have to perform this routine every time you have to run Micrografx Pictures. But again, it takes 5 seconds to do it, and I love the program, having used it for over 10 years. Photoshop is far more advanced but it takes time to master it, and I do with Micrografx the same quality work as many with Photoshop.
Of course, Janet, you and I have to come to grips with the fact that Micrografx is pretty much dead, and Photoshop is alive and blooming. Maybe this Vista incident is a sign for us to learn Photoshop?
Apr 18, 2009 | Micrografx Webtricity 2.0 Full Version for...
Designjet 750c driver
**if you don't find a good driver, updated for your Windows version, go here
www.plotterdriver.it
Third Party Product
and they are those recommended from HP, Autodesk and workgreat with Corel Draw, Power Point, Micrografx Designer, EXCELL,Lotus, Word and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA.
You'll find all informations
Apr 06, 2009 | HP DesignJet 750c plus InkJet Printer
Micrografx Designer Technical Edition 4.1 Full Version for PC Logo
Top Micrografx Computers & Internet Experts
Tom Chichester
Free Robux
Free Robux
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
