Question about GE Washing Machines
On my crosely washer caw9244xq2 no fill at all
This is a brand new washer it will not fill at all will not sense at all the lid switch does lock and has power to timer but nothing else help
srsrs_1999
  • 9 Answers
SOURCE: washer only fills. then completly dead.(timer still advance)
is there any humming coming from under or front of your washer? whirlpool built machines for about 10 years now are "direct drive" ...the motor has a plastic coupling held in place by a rubberish plastic donut type of thing, its an inexpensive fix and there are videos on youtube on how its repaired..its under 10 bucks and usually cures any lack of agitation/ spinning ...i had a roper by whirlpool and once i replaced it from a parts machine i salvaged it was fine.. so check you motor coupler/ coupling and that maybe your answer, if not there is a set of wires and a cut off in back of the motor to prevent overheating, which may have tripped..also a good point to check.. good luck
Posted on Apr 30, 2009
smartr10U
  • 1305 Answers
SOURCE: Washer is "dead." Was stopped after fill up, and now no power.
Try pushing firmly on the center of the lid.... with the lid closed... it could be that the lid switch isn't making proper contact to turn the machine on.
If this is the case, you can open the lid, and while holding the lid open with one hand, put firm pressure on the rear lip of the lid right in the center..where it makes contact with switch...
This was a common occurence at my laundromats because people would sit/stand on the machines..
Hope this gets ya up and runnin'
Posted on Jun 20, 2009
  • 7 Answers
SOURCE: Whirlpool washer lsq9010pw -Timer not advancing
you can also check to see if the timer motor is good. not a good idea to bypass. if the presure switch was bad it would not stop filling up.
Posted on Aug 22, 2009
  • 7 Answers
SOURCE: Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Posted on Aug 24, 2009
Testimonial: " "
VtToolMan
  • 704 Answers
SOURCE: How to Find Lid Switch on Maytag Washer
The newer top loading washer designs don't use standard switches as was typical many years ago.
Today, these washers use a magnetic switch, and bypassing is not easily possible, due to the logic circuits that monitor the washer and all the various cycles.
For any reputable tech to provide a instructions to bypass any safety feature, would be highly irresponsible and would expose us to legal action by this site and the product manufacturer.
Please understand, providing a way to defeat a product's safety feature is against the law and will remain on the internet for years to come, along with the person(s) that provided it, exposing me and my family to a potential lawsuit - sorry, but I wouldn;t do that for my own family, yet alone some stranger.
Just chaulk it up to new technology, just like seat belts and air bags have changed auto safety.
Hope you understand and find this Very Helpful - Enjoy your new washer and best regards!
Posted on Aug 26, 2009
Testimonial: "I suspected there wouldn't be a way to bypass it, but thought it was worth asking. It'll make laundry take a little longer. Thanks for the help! "
May tag centennial top load washer will not agitate clothes
The most common cause of this is a defective washer lid switch. Follow the link for a repair guide. How to Replace the Lid Switch Lock Assembly on Top Load Washer Repair...
Jul 13, 2017 | Washing Machines
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
What is wrong with a washer that fills up with water lid lock clicks but will not do anything else just clicks?
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
May 14, 2015 | Whirlpool WTW4800XQ Washer
Spins basket once then won`t start blinks 7 times
Check switch under the top of the lid it will not be working feel around under the lid located usually on either side
Apr 30, 2015 | Whirlpool Washing Machines
Washer fills with water and then stops
Most washers will fill with the lid open.
Then, the lid has to be closed for it to start agitating.
This is sensed by a switch for the lid.
The lid safety switch is where I'd start to look at.
Oct 05, 2013 | LG Kirkland
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
CROSLEY WASHER CAW9244XQ2 NO FILL
Hello Greg Aguilar - Are the house valves turn on fully? Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Since you have just recently purchased the washer, I strongly suggestion contacting the manufacturer for a listing of certified techs that can move forward accurately.
Dec 09, 2012 | GE WBSR3140DW Top Load Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
