Question about Ovens
1800w solarspeed halogen hotplate does not work
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: halogen hotplate will not turn down
You need to fit a new regulator that controls the hotplate, as the other one is faulty.
Please rate my fixya solution.
Thanks
Posted on Feb 04, 2009
Back right hotplate getting hot when oven on
That hole is most likely a vent for oven where some heat escapes.
Nov 10, 2017 | Hotpoint Ovens
Need illusrated wireing diagram for 18 year old defy gemini petit chef electric stove
Oven:
power comes in, goes to overtemp > timer > function switch > thermostat > element then back to neutral
fan & light come on with function or thermostat switch.
what else do you need to connect?
Oh, hotplates. Power in > infinite switch > hotplate and indicator then back to neutral.
Watch out for two phase with indicator light.
Oct 18, 2013 | Ovens
I have problems with my Hotplate!!!!! Name of the hotplate is just Induktion. The Hotplate is a Induktion and after a moment of heating it starts to blik and shots down with the Error: E R
From my previous mechanical engineering work, and have maintained a few of similar problems, but different maker. I found one one thqat it was not properly wired, check the owners manual and go over wire diagram. Secondly, is the kitchen on the other 2 I did the breqaker for that room was way over loaded, and sometimes it will shut your equiptment down b3efore the breaker goes off. This is because when the element reaches a certain tempature, or even rising in tempature the stove will kickback, almost like a car going into safemode, so it does not destroy the stove. I had to call an 3electrician, because3 I am not a certified elec.
Dec 26, 2012 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
When i turn on one of the hotplates it trips the electric out how do i fix it
Remove that hotplate. Reset the breaker and see what happens,
Other hot plates do the same?
Jan 28, 2011 | Ovens
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Halogen hotplate will not turn down
Thanks
Feb 04, 2009 | New World E70DOa Electric Double Oven
The hot plate is heating up when the selector is in off position
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Dec 15, 2008 | Ovens
Halogen ring not working
Hi .
It sounds like the temp control is faulty.
Either way you are going to have to remove the hob top to access the controls and elements, Then you can check if the element is getting a feed to it.
Sometimes you can see if the element has gone, .
If you need any further help, let me know.Good luck.
Nov 23, 2008 | Ovens
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
