Question about Fujifilm Finepix Xp50 Camera Digital Orange - Fuji
XP51 finepix says 'memory card protected'...my cards are not locked. How can i fix the camera?
Any card i put in the camera says 'memory card protected' and wont take a picture. The cards have the slider down and NOT locked and i have tried all my cards 1,2,8 and 16GB and all cause the camera to say this message. It is the camera at fault i think....but what to do??? thanks
Bubbabear64
  • 2794 Answers
SOURCE: camera says Frame no full cant take anymore pictures Help!
Copy your card to hard drive, reformat your memory card, and see what the numbers of pictures it gives you.
If you lower the resolution of the camera, the more pictures you can take.
Posted on Jun 16, 2008
albumflaps
  • 16 Answers
SOURCE: Fujifilm FinePix Z20fd protected card??
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Posted on Feb 13, 2009
robmcd27
  • 423 Answers
SOURCE: my DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Posted on Feb 27, 2009
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Posted on Dec 22, 2009
SAFFOTO
  • 77 Answers
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Posted on Jan 29, 2010
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
Turn off protected mode
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 10, 2012 | FUJIFILM FinePix JX310 14.1 MP Digital...
Protected memory card on S2980
May 20, 2012 | FUJIFILM Cameras
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
My fuji finepix a200 camera is showing protected card. i cant get it to go off. How do I fix this
I'm going to show you a diagram that has to do with the card lock on the side of your memory card this slide is there to protect a card with images on it so it's not put back in the camera and formatted
Once you have unlocked the memory card you need to format the card to make it ready to accept new pictures from your camera. I hope you download your images first before formatting.
Dec 25, 2010 | FUJIFILM Finepix A200 Digital Camera
Every Time i Put In My Memorie Chip It Tells Me protected Card It also don't let me erase or go to the menu, how can i fix it
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 29, 2010 | Fuji Finepix Z20fd Digital Camera
I put my memory card in my camera and it says protected card how do i use it on my new camera?
Your memory card is protected and this is why you cant take pictures.
To solve the problem do the following:
  1. Remove the memory card.
  2. On the side of the card you will see a switch. This locks or unlocks the card.
  3. Change the switch to unlocked by either shifting it up or down.
  4. Put the memory card back into your camera.
Your problem should now be solved!!
Enjoy taking pictures!!
Regards
Jan 07, 2010 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Protected card warning
the SD Memory Card switch is to the "Lock" side. (remove memory card)unlock the protection by sliding it back (u can c a small switch in the side of memory card)... this has to work.... happy photography.....
Sep 21, 2009 | Fuji FinePix J10 Digital Camera
Camera or memory card "CARD FULL" error
Check to see if in your settings you are putting the pictures onto the memory card or the cameras internal memory. If there is no internal memory, then I guess that's no help. Also check to see if the card is write protected (a little switch on the side of it).
Apr 13, 2009 | Fuji FinePix Z2 Digital Camera
My DSE memory card says 'write protected'
Hi there, do this:
Rob
Feb 27, 2009 | Fuji FinePix A340 Digital Camera
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
Fujifilm Finepix Xp50 Camera Digital Orange - Fuji Logo
57 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
