Noisy superser gas heater
Noisy flame
4 Suggested Answers
  • 2976 Answers
SOURCE: When the heater is off, the pilot has excessive
It sounds like there is a hole in the tube, near the flame. You should have it checked. It shouldn't even be as noisy as a gas stove.
Posted on Mar 04, 2009
hardrocko
  • 1476 Answers
SOURCE: on a patio heater why is the flame yelow and noisy
Your gas/air mix is not correct. Not enough air. You should be able to adjust the unit and correct this. Read the manual first to find the adjustment and procedure. When properly set the unit should have a blue flame with a white or very small yellow tip. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 05, 2010
  • 3315 Answers
SOURCE: helius superser calor gas heater
Blocked pilot could need cleaning, spark electrode could need cleaning or out of postion .
Posted on Mar 03, 2012
Superser gas heater lights but wont stay alight new thermocouple fitted
The tip of the thermocouple needs to be moved closer to the pilot flame.
Feb 02, 2015 | Heating & Cooling
Superser flame goes out when button released
usually you need to hold a button down for a while, up to 30 seconds, if it still goes out you need a new sensor
Jan 10, 2015 | Heating & Cooling
Richmond 5v40-7 gas water heater. Burner lights completely but flame is very low. Does not grow above 1/4 inch.
Is flame clear blue or yellow?
Yellow flame, clean the flame arrestor screen
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Flame is blue:
Low gas pressure.
Bad gas control valve.
Dirty combustion parts.
Clean the water heater parts and catch up on maintenance.-
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 01, 2014 | Water Heaters
Pilot flame noisy and lifting on procom ml150tpa heater; how to adjust the flame
Take the valve apart and make sure the seal on coil is not damaged have also seen the snap ring come off
Mar 04, 2014 | Procom Heating & Cooling
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
On a patio heater why is the flame yelow and noisy
hardrocko
May 05, 2010 | Heating & Cooling
Noisy pilot light Vulcan Quasar 40
Simply clean out the jet tube with a fine wire, the sound you hear is the gas blowing by the irregular edges, and swirling and not mixing and producing sound waves, (Bit like a flute) So, you need to clean the tube right out, and smooth off the end again, & sorta "Countersink", Flame the end too, at the end.use a very fine needle file, and make it look like new, that will sort your problem out. Then adjust so you have a good gas flow. Also check out it isn't blocked too.
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
When the heater is off, the pilot has excessive gas blowing out of it making the flame very loud and noisy.
Mar 04, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
