Question about RCA 27F530T 27" TV
YPbPr inputs not working
I have a 27F530T and an Xbox 360. When I plug the Xbox into the TV's YPbPr ports, all I get is a box on the TV saying "Unusable Signal," but the sound still works. I know that the problem is not with the cables or the console, because I have hooked the Xbox into the YPbPr on my Samsung TV with no problems, but the RCA TV is giving me no picture at all. I have also tried fooling with the Xbox resolution settings to no avail. I would try plugging the Xbox into the TV using the single yellow plug as opposed to the YPbPr inputs, but I use a monster Xbox cable that has no yellow plug, only the YPbPr (a real pity). Thanks.
  • James Kirk Jun 11, 2007
    Oh, I forgot to add, I've also tried adjusting the TV, but there is no relevant menu or anything in the 27F530T, so changing the settings on the TV won't work for me.
    I've got the Xbox plugged in to Video 2 input, and it says CVideo2 on the TV when I select the channel. Also, sound is coming through the TV from the Xbox.
    One note is that there is both a component and composite input on the back of the TV in the same box labeled Video 2, but when video comes in through the Y/Pb/Pr inputs, the screen says CVideo2 instead of just Video2, so I believe the TV recognizes the difference.
    Scholar:
  • 39 Answers
Hi there. I might add my 2 cents here. On the back of the TV, video2 is both composite, component and audio jacks, all at the same input. So you say 'the screen says CVideo2 instead of just Video2, so I believe the TV recognizes the difference'. You're right. Now, are you sure the component cable you're using on the xbox is good ? You could try to connect only the green connector of the component cable to the yellow composite RCA video input of the Video2 input, and see if it displays any video. Else, i'd try to reset the xbox 360 video settings of the dashboard to defaults; here's intructions on how to do it : To reset the display settings of the Xbox 360 console to the default settings, remove any discs from the disc tray. Turn the console off and turn it back on. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. The Xbox Dashboard resets the display settings to the default settings, and then automatically restarts the console. Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller. Make sure that you use the player 1 controller when you do this. The player 1 controller will have the upper-left quadrant light illuminated. Hope that helps a bit. Thanks, cheebster.
Posted on Jun 18, 2007
  • 934 Answers
Tacz, What video input# on the back of the TV is your component video?? Are you sure the TV is set to look at that video input#??? You may be looking at one of the composite video inputs as far as the TV is concerned and with nothing plugged in to that input the TV would naturally give the error message you indicated. Let me know.. Bill
Posted on Jun 11, 2007
  • William Rayburn
    William Rayburn Jun 14, 2007
    It sounds to me like the TV is indeed recognizing the difference. I didn't quite understand what you meant by, "...and it says CVideo2 on the TV when I select the channel." You should not have any channel to select on the video input#2 merely selecting that as an input on the TV is enough to have the TV look at that input for a video source.
    Stay plugged into the video input #2 and on the factory remote, left lower side of the number pad you should find the input button. Press the button until the TV display says video 2 then swap each of the cable ends onto the yellow RCA connector in the back and see if you get the picture up...
    Bill
How do i get my xbox 360 to work with my tv which is a emerson lc501em3
That TV has an HDMI port so I recommend plugging it in using an HDMI cable. Once you've plugged it in via HDMI, turn on the TV and change the TV's input to the HDMI port. Should just be a matter of finding a button on the TV or the remote labeled "input" and hitting it until it's on the right port.
Feb 10, 2013 | Video Game Consoles & Games
I have an RCA Powertrak tv that does not have the remote. I have a cable box that has an audio imput section that i hooked to my xbox 360. I have run an auto program and it does not find the channels that...
First, remove the XBox from the cable box and move it to the TV inputs. Use the menu on the front of the TV to change the input device you have plugged the XBox into and it will work. In other words, connect the XBox to AV2 in the rear of your television and select AV from the menu as the input for your device and the XBox screen will appear. If you reconnect your cable to the cable input on your cable box and connect the output to your AV1 on the TV, it will detect your stations, as long as you select Cable from the menu for input type. Let m know if you understand what I am saying.
Sep 09, 2011 | Televison & Video
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
I can't get Xbox 360 to work. I hve old TV, using converter box
If there's an issue with the AV cords themselves, the xBox's ring will flash red in all four sections.
You might want to try clearing out any dust or debris in the plugs and plug-inputs with some compressed air.
That's all assuming the AV cords or the converter are the problem.
Dec 03, 2009 | Microsoft Video Game Consoles & Games
The inputs on my tv arent workin, how can i hook my xbox up to alternate sources in order to play?
Well you need a TV. What happens when you connect check the switch on the AV cord that plugs into the 360. If you have no RYB or rca ports that work on your tv buy a nice used CRT tv from cragis list for 20-40 $
or check http://rns-systems.com/ for a used LCD
Oct 16, 2009 | Microsoft Xbox 360 Console
How I hook up an XBOX 360 to digital converter box (TV does have yellow/white/red jacks). Also have rabbit ears for antenna. Thank you.
you don,t , the xbox 360 will have component cables and posibly an hdmi output , but you can plug the component cables directly to the tv in a auxillary input and on your menu screen it will either say video1 or video2 or video 3 ,you can put the cables from your xbox into those inputs on the tv and as long as your tv is also at that input you should have a signal , hope this helps ,glenn
Mar 02, 2009 | Insignia Digital-to-Analog Converter for...
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
No Sound on Xbox 360
Very often on HDTVs there may be more than one YPbPr connection... That is the Red Green and Blue. Under each one, or next to, or above, there should be separate red and white audio hookups for each set of YPbPr hookups.
Make sure they are hooked into the corresponding plugs.
Hope that helps.
Jul 15, 2008 | Microsoft Xbox 360 Console
Brand new xboxdoes not play in color on TV set at school.
Does his TV have other RCA in ports? If so, he should try connecting the 360 to the other one as it could be defective. If he connects a DVD player to the same ports, does he get the same problem? What sort of cables is he using? If he's using a component cable (RGB or YPbPr), he should try using a normal RCA cable. Also, when connecting the 360 to the other TV sets, did you use the same cables he used when he connected it to his TV set? If not, you should try switching the cable.
Jan 07, 2008 | Microsoft Xbox 360 Console
RCA 27F530T 27" TV Logo
1,757 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
