Question about OKI Office Equipment & Supplies
Supplier access not defined
This error comes up everytime my user tries anything at all on the printer.
2 Suggested Answers
SOURCE: fuji work center 222/228 message
You need to setup a provider in the printer:
From Internet Explorer connect to the printer via its’ IP address and click on “Enter”,
then select “PARAMETERS” è Internet - Initialization
then from “Select a provider” click on down arrow and select “LOCAL NETWORK”
Click on “Confirm your modifications”.
This should fix the problem.
Posted on Oct 08, 2008
A printer error has occurred. See your printer documentation
Which printer? Try looking for user manual (documentation) here: Download Free Manuals
Jan 05, 2016 | Office Equipment & Supplies
Everytime i try to print from computer code 52.00 comes up what does it mean
The 52 error code indicates that there is a problem with the laser/scanner or the engine control board inside the printer. Sometimes re-seating the connections between corrects this issue. More than likely however, the laser scanner probably needs to be replaced. This is not a end user replacable part and takes a bit of know how.
Oct 04, 2010 | HP LaserJet 2420n Printer
Service error 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon Pixma iP4500 InkJet Printer
Unable to open up Kodak home center or scan anything
Un hook the printer and un install the software and restart your computer. Then put the software disk in and reinstall leaving the printer unattached until instructed to connect it.
Jul 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Please define default access point first
Default access point is the first method of accesing the internet. It could be ur GPRS connection or the WiFi connection or whatever you have. Once the default fails for whatever reason, it will ask for other methods other than the default.
Apr 25, 2009 | Nokia E61i Cellular Phone
E-90 error at epson stylus pht 250
I see now that your printer is an Epson Stylus Photo 250. The error E90 is not defined, other than "contact Epson". However, other users have reported that clearing an obstruction fixed the problem. Try this.
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Gently move it backwards and forwards to see if there is any obstruction. Look into the print head parking area on the right - does anything there appear to be causing an obstruction? Report back.
Jan 28, 2009 | Epson Stylus Photo R220 InkJet Printer
Service error 5100 on my printer.
Hi
Hope you come back for this
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
Solution 1:
Solution 2:
Jul 09, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Fuji work center 222/228 message comming up supplier access not defined when trying to send document to email address ???
May 29, 2008 | Fuji Office Equipment & Supplies
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
