SC 542 is a fuser code that may need resetting. and this should be only done by an qualifyed service representitive as it requiers going into service mode and going into copy sp 5-810 and having it reset or if this does not work you may need a new fuser unit! Again service mode will need to be entered to reset the SC542 as this is a safty feature built in to the copier to keep it from ferther damage
Each time I try to print from WordPerfect to the printer, I must set the paper size to 8.5 x 11. For...
(More)
Each time I try to print from WordPerfect to the printer, I must set the paper size to 8.5 x 11. For most of the rest of our office, it just prints.
Hi I've got an Ricoh Aficio CL3800 which has started printing black marks (small dots) each dot is...
(More)
Hi I've got an Ricoh Aficio CL3800 which has started printing black marks (small dots) each dot is about 3cm apart but line up accross the page when we run off prints - the problem happens on both b&w and colour. Any advice would be appreciated.
error code SC555 Power off on This happened once befor. There was no problem with the fuser. A...
(More)
error code SC555 Power off on This happened once befor. There was no problem with the fuser. A technician walked me through the process to reset the code. Can someone help me reset it?
