Ricoh mp4000 sc400
Error code sc400 ?
3 Suggested Answers
Ickoajnc
  • 203 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
Al Mamun
  • 8 Answers
SOURCE: Ricoh MP4000 error code SC441 how do to solve
SC 440/441 Main motor Lock/Main Drive section Jam
tray You the condition
01. Press Clear/stop Key (Yellow Key) 2 tarms
02. type 107 same time
03. Press hold down clear key 5 secend ( red key)
Belinkin 1 on the copy counter left hand side
04. type 5 and press # ,type 810 and press #
05. tarn of the machine and tarn ON the machine.
nasmamtrade@yahoo.com
088-01710-950 340
Posted on Jan 26, 2010
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
How do I fix the error code SC400?
I don't know what is your printer model, but I am sure, that this mashine needs cleaning. The main problem should be that the ID sensors of image transfer belt are dirty. You need technical skills to do that.
Apr 08, 2015 | Ricoh Aficio Office Equipment & Supplies
I have an error code SC400 of Ricoh machine
That code is main motor lock open and see if there nothing blocking the motor like piece of paper
Apr 07, 2015 | Ricoh Office Equipment & Supplies
Spc 220n has a sc400 code
Process Control Error
This SC is issued if the process control adjustment fails 5 times consecutively after AIO
replacement.
• Defective contact at the terminal between the machine and AIO.
• Dirty TM sensor
1. Check the contact of the terminal and re-install the AIO.
2. Clean the TM sensor.
Apr 09, 2013 | Ricoh Aficio SP C220N Laser Printer
Me marca error sc400 una ricoh c2030
hola tengo una maquina ricoh aficio mp c2030y me marca error sc400 Que es y como solucionarlo
gracias!!
Jun 13, 2011 | Ricoh Office Equipment & Supplies
Hi all Lanier Ld 520c Error code 400 what is it. Thanks
sc400 is an ID sensor error. You probably only need to clean the ID sensor, rather than replace it, but there's a chance it could be something more serious, like a board or the transfer belt assembly.
Getting to the ID sensor is tricky -- you may want to call a service technician. The fuser needs to be removed and the whole right side door needs to be taken off. But chances are that once that ID sensor is cleaned and the machine is turned off and back on, the sc400 error will go away.
Dec 16, 2010 | Lanier UNKNOWN
With a printer/copier Ricoh spc221sf, giving code sc400
sc400 is a process control error. Did you just replace the all-in-one toner cartridge? If so, take it back out and try again -- it might not have been in all the way. If the error still occurs, check the contacts between the toner cartridge and the machine -- they may have gotten bent or dirty.
Mar 08, 2010 | Ricoh Aficio SPC210SF All-In-One Laser...
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
256 people viewed this question
k24674
jasbo
jasbo
