Question about Intel Motherboard
System in hanging
Hi All,
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem. My system Configuration as mentioned below.
Intel 845 GVSR Motherboard
128 MB DDR1 Ram With 266 MHZ speed
    Problem Solver:
  • 18 Answers
Try to replace your RAM
Posted on Jan 16, 2009
Hi, The situation is My system INTEL PENTIUM
Do you have any extra things plugged into the usb ports? (external hard drive,Ipod,Flash drive) anything like that can sometimes cause pc's to hang at boot they will try to boot to that device instead of your hard drive
Mar 07, 2011 | Dell Inspiron Desktop / Intel Pentium...
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.My system Configuration...
There are different possibilities for system hang up. I want you to find it your self from following my simple instruction.
1. (when computer is turn on) Check temperature... overheating can cause system to hang up, it can cause the system to reboot, it can cause the fatal error message and turns your screen to blue. Overheating is cause by exhaust fan or blower not working. Find this blower or exhaust fan on top of the processor, as built in fan in your video card, attached on your power supply and on the casing of your computer. Replace non working fan or blower.
2. Check video card...faulty video card can cause your system to hang up. It can cause also your system to go on blank screen. Most common problem is loosen connection of video card from the motherboard. Disconnect and reseat the video card properly. Inspect the fan, if not working then video card will overheat and system fail. If you previously see moving colors in your screen especially small boxes, or discoloration and screen going black and white then it means video card is already failing. You will need to replace it.
3. Check for hardware failure. keyboard, mouse lan card can cause your system to halt and hang. You will need to disconnect this first when booting and see if by removing this hardware will complete the system to boot up to operating system. Replace faulty one.
4. Harddisk failure. when computer reset or will not boot up completely then hard disk usually cause this problem. Initial remedy is to reseat its connection sata, ide or power supply connector.
If you hear ticking sound in the harddisk or excessive vibration then it will need replacement.
5. Operating system corrupted. this can cause your computer not to boot up properly and hang the system. Reformat and reinstallation of operating system is required.
6. Power supply failure. you need to check the output voltage. dropping of voltage can be cause bi leaking capacitor in the power supply unit. replace it with exact value. Voltage should read +12VDC for yellow, +5VDC for red. and should be stable even with load.
let me know which one cause it.
Feb 07, 2011 | Intel D845GVSR Motherboard
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
I have a problem with my Nokia N72 cell phone it is not displaying anything just a white colour is displaying"
nokia n72 has a slow operating system which gets even slower if the battery is low and thw problems are doubled if the memory is near full. Sometimes unsupported applications hang on it which can only be stopped by removing the battery and restarting the phone.Restarting may take a lot of time but have patience and once the phone restarts delete the application which caused the hanging. An advice is to keep the memory card half empty.
Mar 20, 2009 | Nokia N72 Cellular Phone
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Nov 06, 2008 | Gateway Computers & Internet
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
Issue related to mobile motorola rokr e6
It may be corrupt internal firmware in the phone, or you may have an application installed that is causing its main processor functions to hang. There may be an intermittant hardware failure.
These are common faults that cause most of these phones to stop functioning. I would start by wiping it clean, and re-installing its firmware and operating system.
Jerry G.
Jul 30, 2008 | Motorola Mobility ROKR E6 Smartphone
Hang/reboot
What type or modelof motherboard did you use now?
Feb 19, 2008 | Intel Pentium III, 800MHz (229725001)
Sansa C140 hangs while switching on displaying SanDisk Logo
My Sansa C140 hangs up while switching on, it only displays SanDisk Logo. Plz help me to solve this problem
Dec 25, 2007 | SanDisk Sansa c140 MP3 Player
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Intel Motherboard Logo
99 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
