Question about Sony Str-ks360 5.1 Surround Sound System
How to program my Sony Receiver to my remote
I just need codes for the sony str-ks360 to program to my direct tv remote.
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
  • 336 Answers
SOURCE: Need a remote for for Sony STR-DE597 Receiver.
Bad news, most every universal remote is for tv, vcr, dvd, cable box, and nothing else. you can goto sony.com or check ebay for a new one.
Posted on Feb 24, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
  • 99 Answers
SOURCE: I have Sony STR DE845
If you consult the card that came with the remote, you will find several codes for "Sony". You will need to experiment with each code until you find one that will power the receiver on and off. Then you will have control of the receiver. If you don't have the card, then go to the web site and download a copy in PDF format from there. I have a lot of Sony stuff, and I have found that the codes varry according to the year the equipment was made and its function.
Posted on Aug 31, 2010
Need remote control programming codes
I assume you have purchase a universal remote control...if the programming codes for your Sony STR-DE675 receiver is not listed in the remotes code guide, then you purchased the wrong type universal remote. Make sure you get a universal that does stereo equipment or check eBay for a reasonable price on the original.
Jan 07, 2014 | Sony STR-DE675 Receiver
I need the code to input to a universal remote for my Sony STR-DE325. Please help.
I just got mine to work with the STR-DE325. I programmed my Dish receiver remote following the reference in the back of the Dish receiver manual. I missed the comment at the beginning of the receiver codes at first which stated to enter a 2 before setting a tuner/amplifier code on aux. I then used the first code listed which was 683 and it works. So it was hold aux on the remote, wait until the aux was enabled by blinking, enter 2, enter 683 for the Dish remote and enter pound. E. LaPierre
Jan 18, 2011 | Sony STR-DE325 Receiver
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
Dec 21, 2008 | Sony STR-DE597 Receiver
Need Insignia TV code for my Sony Receiver Universal Remote Control
Try This link it worked for me.
www.insignia-products.com/universalcontrolcodes.aspx
Jan 06, 2008 | Televison & Video
Sony Str-ks360 5.1 Surround Sound System Logo
274 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
