Question about Whirlpool Dryers
Whirlpool dryer model lgn1000pq0 keeps running and wont heat
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 18 Answers
SOURCE: Whirlpool dryer keeps running, doesn't heat up
Yes. If the timer does not advance, it is a timer issue. the heat may or may not be related, try replacing the timer first.
Posted on Jan 21, 2009
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
localwonder
  • 6784 Answers
SOURCE: kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Posted on Jun 01, 2009
localwonder
  • 6784 Answers
SOURCE: Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
2. Heating element
3. Thermal fuse
Posted on Jun 02, 2009
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
The dryer wont heat-it over 5 hrs to dry a load. it would not turn off on automatic side & just keeps running. it turned off on the timed side
If it's not making heat the humidity sensor will never dry out, therefore it keeps running. It sounds like your heating element is bad.
Jan 20, 2014 | Whirlpool GGW9200L Gas Dryer
Wont heat on low heat only on high heat and keeps running
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 15, 2011 | Whirlpool Dryers
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
Open Questions:
Dryers Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
