Question about Dishwashers
Hi I have a Omega Technowash which wont carryout the pump function i think a solenoid may be u/s can anyone help?
Unit will go through full number 3 cycle but wont pump the water out
  • 38 Answers
SOURCE: Unit not pumping on wash cycle
Could be bad main wash pump motor, bad capacitor on said motor, or broken or jamed pump impeller. You will need to remove the lower spray arm and filter assembly to get access to the pump impeller to see if it is jammed or broken. If you can turn the motor shaft but the motor just hums then the motor of motor start capacitor is gone. You can order the motor with start capacitor and impeller for around $130. Check for 120v at the motor terminals prior to replacing motor/pump assembly to confirm, 120v at motor would but motor not turning equals bad motor and or capacitor.
Posted on Feb 23, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
  • 142 Answers
SOURCE: how do i remove the pump off my bosch
inside the dw remove all filters and in the sump there is a cover over the impellor with 1 self tapping screw remove and there could be a object stopping pump.
Posted on Sep 14, 2009
  • 3247 Answers
SOURCE: i am a licensed plumber
I can see from what you have described (by the way it is a very clear and precise description which is very helpful), there is a problem in the water circulation system. These dishwashers use an alternating water flow method to split the water circulation between lower and upper wash arms in alternate cycles.
The way it is done is by use of a small ball that reciprocates between two holes in the water distributor. See item 58 in this diagram. It is possible this ball is blocking the pump impeller and causing the grinding noise.
You will have to open the assembly and check it out. You may need to replace some of the parts if the damage is too severe as there is a degree of precision required for the water jet to go through the right contour to create the flow.
Good luck. Take photographs at each stage so that you know what goes where.
Posted on Nov 24, 2010
  • 154 Answers
SOURCE: Omega Technowash Dishwasher. Model DW
Hi
You most likely have a fault with the Thermostat. That is common on Omega Technowash which is similar to a Smeg dishwasher. More often than not the Thermostat fails rather than the heat element. However, not to completely dismiss a failed heat element.
The thermostat is not very expensive. If you don't have the means to test the element or thermostat via a multimeter, you can order the thermostat to have a go at fixing it yourself.
Unplug the machine from its power point.
"Two screws in the front kick plate. Open these and lift off kick plate. When you open the dishwasher door you will see an L-shaped heat element which is on the bottom of the bowl on the left and back of machine. The Thermostat is the round metal head situated on the front left in between the element coils. When you look from underneath inside where you have removed the kick-plate you can see two wires going to your heat element and 4 wires going to the Thermostat (either 2 White and 2 purpule) or (2 red and 2 white).
The thermostat is pushed in from the bottom and sits in a groove of a rubber seal. You can pull it down and out from underneathe and twist and push up the replacement in its place. Make sure the sharp metal edge of thermostat is poped insided the groove, otherwise the machine will leak.
Try this first, I am fairly sure it is the thermostat. If you have a multimeter you can check continuity of the heat element.
If you think this solution helped you please vote 4 thumbs up and give me a testimonial.
Thanks
Ash
Posted on Sep 22, 2011
Omega technowash won't fill
Many times the problem lies in the water inlet valve. It is not hard to replace and you will find it where the waterline hooks to the dishwasher. You can goole appliance parts stores and find a number of companies that you can order from.
Apr 28, 2014 | Dishwashers
Vauxhall omega 2.2 auto 52 plate wont change gear up or down i think its stuck in therd ?
the solenoid controller inside the auto box is one fault that can cause this. they can wear out. having a ob2 reader put on the gearbox ecu will tell you.
Oct 10, 2013 | Cars & Trucks
Omega Technowash Dishwasher. Model DW 2005 WH. The electro-mechanical timer stops just after the dishwasher powder is released and again near the end of the cycle. Also the water is not heated and no...
Hi
Thanks
Ash
Sep 22, 2011 | Dishwashers
I have an Omega Technowash, approx ten years old. Model No. unknown. It has a round push in knob with 4 settings. Problem: It will only perform one setting at a time before stopping, then needs to be...
This is the mechanical TIMER switch which is the main program controller unit. It seems that the controller has failed in the contacts or the stepper motor not advacing automatically due to wearing on the gears.
Hence you need to manually move the program forward.
The option is to try for a scrapped controller as many are easy to find from old repair stores, replace after you make notes of the wires to the controller.
Finally try and see if a degreasing spray can release or ease the movement if there is a possible jamming of the motor-- If motor is not running at all it could have failed.
Jul 22, 2011 | Dishwashers
Omega wd 1067 washing machine front laoding washing machine is failuing to do hi speed rinse has anyone sufered this problem
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $#@!
Oct 10, 2009 | Washing Machines
I have an Hitachi ex40 excavator. it has started to nearly stall
I have a EX200-3 it starts but has no power. when I use any function it wants to stall. Except for the bucket function, when i use this function the engine frees up. I brought it to a mechinic but they couldnt find the problem and even made the problem worse. So when I start it up the engine sounds like there is a heavy load on it and ready to stall, this problem began and has become worse to the point I can not use the machine. Help please....
May 26, 2009 | General Garden
NEED MANUAL FOR ALPHA OMEGA CAR SEAT
I have an Alpha Omega that I bought 3 years ago. The phone number is 1-800-544-1108 but I dislike waiting so let me know what you need to know and I'll help as best as I can. I don't think the carseats change very often.
The "experts" say that it isn't a good idea to use a carseat if it's more than 10 years old.
Hope I helped.
Misty
Jan 09, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Omega urc-08 device codes
Original link no longer working. Found this: http://files.remotecentral.com/download/220/urc08-manual.zip.html
Comment if it's wrong one.
Nov 22, 2007 | Televison & Video
Dishwashers Logo
Top Dishwashers Experts
