Wont drain,, ive checked the spin thing inside the housing at the botom,, the water came out but it is still spinning
  • Washing Mach... Master
  • 19,396 Answers
You need to access the drain pump, if the drain lines are all clean then it is likely a defective drain pump.
The drain pump must be tested before replacing it, by energizing it directly, this must be done by a technician, as there is high voltage in there.
Posted on Jan 13, 2009
Washer will not spin or pump
Have you tried to drain the drum manualy by opening the drain plug, normaly located on botom either in the front or the back.
when drained unplug the machine from the wall socket. then open the backcover, the drainpump are usually located next to drainplug. if not follow the hose connected to drain plug to get to the pump.when you found the pump remove it from the washing machine and strip it to clean the inside of the pump ,the impellor and so on. their you will find some black stuff that will stink a lot ,thats all old soap water.after cleaning put it back together and reinstall it. it should solve the problem, if not check for propper supply voltage to pump and spin motor.
Mar 26, 2012 | Maytag Atlantis MAV6000 Top Load Washer
My washing machine won't spin. i've cleaned the water hose filter and the pump filtre.
Hi eddyloz2000,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Washing Machines
Machine will wash but not drain or spin.
machine wont spin while it has water in my advice is to lay the drain pipe level with the floor (outside of your house) so it can drain if it doesnt drain then you have a blockage anywhere from the drum outlet into the pump to the watse pipe if it does drian then take the pump apart and check it turns freely
May 30, 2011 | Washing Machines
My kenmour washer stopped spinning
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Shane
Mar 26, 2011 | Kenmore Washing Machines
Will not spin
I hope this helps.
Shane
Mar 10, 2011 | Bosch WFK 2401
Wont spin. just makes loud noise.
I hope this helps.
Shane
Feb 26, 2011 | Kenmore 22422 Top Load Washer
Wont spin
I hope this helps.
Please reply with additional details for further assistance.
Shane
Feb 12, 2011 | Kenmore 98702 Stacked Washer/Dryer
GE Washer wont drain. Wont agitate, does nothing. Washer is part of a stackable unit about 4-5 yrs old. Checked circuit breakers and electrical and water supply. What should I check? Are there fuses inside...
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is a link to the part you need.
Jan 10, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Not draining or spining
hi pete.these washers wont spin if they cant drain.so because of your standing water your pump is blocked or not working .most off the time its blocked.remove frount pannel and get to pump.see if blocked.if not wound have to do voltage check when in spin.please help me with my ratings if ive been helpful.God bless tom
Jan 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
