Won't switch on
Sometimes it will sometimes it won't switch on
  • 2 more comments
  • yorkt20 Jan 14, 2009
    My DV9000 won't boot up. The led comes on and after 20 seconds it goes off,comes back on for a few seconds then shuts off.
  • Vincent Martins
    Vincent Martins May 11, 2010
    Did you solve the problem already?
  • Muggs01
    Muggs01 May 11, 2010
    Whats the actual Problem.
  • Verne Koti May 11, 2010
    does it still do this when the battery is removed and only ac power connected ????
    I assume this is the same laptop ---
    HP Pavilion DV9000 Notebook Full Specs:
    • Screen: 17" WXGA+ (1440 x 900) Brightview standard. Optional WXGA+ Ultra Brightview or WSXGA+ (1680 x 1050) Brightview display.
    • Processor: Available with Mobile AMD Turion 64 X2 dual-core processor
    • Graphics: NVIDIA GeForce Go 7600 discrete graphics with 256MB dedicated DDR2 VRAM
    • Card Reader: 5-in-1 digital media card reader
    • Four USB 2.0 ports
    • ExpressCard 54 slot
    • Wireless: Integrated wireless support for 802.11 a/b/g Wireless LAN and Bluetooth on select models
    • Dual hard disk drive option with combined capacity up to 240GB
    • 8-cell Li-Ion battery
    • Weight: Starting as low as 7.8 lbs
    • Speakers: Integrated Altec Lansing stereo speakers
    • OS: Microsoft Windows XP Home SP2 or Microsoft Windows XP Pro SP2. Optional configuration with Microsoft's Windows XP Media Center Edition 2005
    • Dual stereo headphone jacks -- one with high-definition audio support (S/PDIF capable)
    • Optional HP webcam with integrated dual stereo microphones.
    Please let me know if you need more assistance thanks Misterdj
    Habit-Forming:
  • 62 Answers
If the problem is the living dead laptop, you will need to search for possible damage, one may have the bolt / hardware's to loose, it will remove, clean and then restore
Posted on Jul 20, 2009
Won t start sometimes
sounds more like switch going bad as a lot of people have a pound or so of keys on key ring and wonder why switch went bad ....but they do go bad for no reason sometimes....
Jul 31, 2014 | 1994 Buick Park Avenue
Windows switches won't work intermittently then fuse blows so car won't start
It appears that you have a dead short in the switch, ehich would be like touchin teo wires together. Repkce of switch should solve problem,
Mar 28, 2013 | 2001 Dodge Stratus
Intermittent starter won't engage on mercrusier7.4 1988 boat engine
might be a burned spot on the starter contacts where the brushes power the motor.
tap the starter to see if problem goes away.
sometimes you can clean the contacts but that is a temporary fix.
Mar 11, 2013 | Cars & Trucks
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
Won't start sometimes
A mechanic would check for voltage at the starter, the neutral safety switch, and the key switch when it will not crank.
Aug 19, 2012 | 2004 Dodge Neon
2004 buick rendezvous sometimes won't start. clicks but won't turn over. replaced starter, battery, and ignition switch. what now??
We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
Aug 06, 2012 | 2004 Buick Rendezvous
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
