Question about Bosch Ovens
BOSCH OVEN HBA74R SELF CLEANING INSTRUCTIONS IN ENGLISH
HBA 74R
SOURCE: cleaning our viking oven
I had to clean mine the old fashioned way -oven cleaner and elbow grease. Fortunately the oven comes apart in ways I never imagined so I could remove, for instance, the sides and bottom and clean them without bending over with my head in the oven!
Posted on Dec 22, 2007
micromaster
  • 3614 Answers
SOURCE: how to use self cleaning oven
  • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
  • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
  • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
  • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
  • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
Posted on Nov 11, 2008
SOURCE: Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
Posted on Nov 24, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
SOURCE: dacor oven self cleaning instructions?
Go to link below and get the manual for your model. http://tv.manualsonline.com/ex/thread/view/idThread/1185347
Posted on Mar 10, 2010
How do I start bosch exact temp self cleaning oven
My Bosch is also self-cleaning. If you press and HOLD the 2 buttons Bake and Broil that will lead you through the process. It starts by beeping at you- don't give up. :D
It will remind you of several things:
Choose length of time (4:00 is standard)
Remove the racks (self-cleaning will make them 'sticky'
and so forth
Keep pushing Start if you are comfortable moving forward.
Hope this helps!
Apr 28, 2012 | Ovens
I'm trying to clean my Bosch oven, model number HES5052U, and twice now it gets 30 minutes into the self-cleaning cycle and then it shuts down... flashing Error 41. Everything seems to run smoothly until...
Allow the oven to cool before running self-clean. Always wipe out loose soils or heavy spillovers before running self-clean. If oven is badly soiled, set oven for the maximum self-clean time.
Here is the manual with "troubleshooting". Hopefully, it will help!
Operation Bosch HES5053U 31 100
Jun 29, 2017 | Bosch Ovens
How to do self-cleaning.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Mar 08, 2011 | Bosch HBL5660UC Electric Double Oven
How do you clean a self cleaning oven? I don't have the instructions. It's a Frigidare gallery convection oven. We bought it used. I just need the Instructions. (it didn't come with any) Thanks Debbie
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 19, 2011 | Ovens
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
heatman101
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
Oven cleaning bosch oven
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Feb 10, 2008 | Ovens
Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
Oven cleaning
Error 41= Data cable shorted to ground//remove cable and reseat
Jan 01, 2008 | Bosch HBL 442 / HBL 446 Electric Single...
Self cleaning oven directions
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
