Question about Sybase Adaptive Server Enterprise for Mac OS X 12.5
ERROR WHILE CONNECTING DATABASE
My hard disk is having two partitions - c for windows 2000 and d for sybase data. Windows 2000 were corrupted but now repaird. But still sybase data is not connecting.
We do not have AMC with Sybase India and hence require cnsultancy from private engineer to connect Sybase server.
Regards,
Ravindra Karambelkar
Hi Ravindra,
send the error log details.
Posted on Jan 19, 2009
Hi I have a 2tb ext hard drive which was working fine on my soniq tv. Somehow the tv formatted/reformatted the hard drive and now none of the files work.. can't even read any of the file headings as they...
I have to ask, why would you connect a Computer hard drive to a television?
Remove the hard from the television and connect it to a computer. The hard drive hasn't been reformatted, because you can see the folders. If it reformatted it would be blank. With the hard drive in a hard drive enclosure and connected to a computer, you can try and read the data and find out why the filenames were altered and bring them back. I am guessing the file associations have been lost, or the file extension has been altered. There is also Undelete software you can use as well as diagnostic software.
Nov 12, 2017 | The Computers & Internet
Power accidental problem and windows computer corrupted
Ask your oem (manufacturer) whch button to press on startup to access your windows recovery.. Ask them how to perform the recovery as well.
May 15, 2014 | Microsoft Database Software A5K-02817 SQL...
Device driver download
STEP 1
Check the Power and Data Cable
  • Check that the power cable is securely connected to the external drive and wall socket (applies only to desktop external hard drives).
  • Do not connect the drive through a USB hub, connect it directly to the PC or laptop. Make sure the power adapter is connected directly to a wall outlet, not to an extension cord.
  • Ensure the cable is securely connected to both the drive and computer.
  • If your external hard drive came with with a Y-cable, use both USB connectors to ensure the drive is getting the appropriate power.
  • If you are connecting to a PC, use the USB ports found on the back of the computer. Avoid using USB ports found on keyboards, monitors or the front of the PC.
  • If the problem still continues, try using a different USB port.
STEP 2
Check the Drive Partition in Disk Management
Even though the drive may not be visible on the "Desktop" or in "My Computer," check to see if the drive is recognized in "Disk Management."
  1. Right click on "My Computer" and select "Manage" from the menu.
  2. From the "Computer Management" window select "Disk Management" from the menu on the left.
  3. In "Disk Management" check to see if the drive is visible. If the drive is found, look at the partition for the drive. New drives will be labeled as FAT32 and have a drive letter assigned.
  4. If the drive does not display as "Healthy," or shows the file format as "RAW," then the partition has become corrupt. It could also be corrupt if the bar above the drive is black and shows as "Unallocated."
  5. To make the drive usable again after a partition has become corrupt or lost start by right clicking on the drive in "Disk Management" and select "Delete partition" from the menu. Then right click on the drive again and select "create partition" from the menu. Follow the steps in the partition wizard to create a Primary partition.
    NOTE: Deleting the partition will cause all data on the drive to be lost. If the partition has become corrupt this may be unavoidable. HGST is not responsible for lost data. It is highly recommended that data be backed up in multiple locations on multiple drives to minimize data loss.
  6. After the new primary partition has been created "Disk Management" will display the drive with an NTFS partition. The NTFS partition is unusable on a Mac. If the drive is used on Macintosh and Windows computers, follow the link below to obtain a FAT32 formatting tool which will allow both Windows and Macintosh users to use the drive.
    http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm
STEP 3
Check the drive status in Device Manager :
  1. Right click on "My Computer" and select "Manage."
  2. From the "Computer Management" window select "Device Manager" from the list on the left.
  3. From the device list, expand the "Disk Drives" category by clicking on the [+] symbol found to the left. If the drive is detected by the system, there will be an entry for your external drive.
  4. If it is not listed under "Disk Drives," expand the "Other Devices" category and see if there is an entry for an "Unknown Device."
  5. Right click the "Unknown Device" and select "Properties."
  6. Under the "General" tab, it will typically display "This device is not working properly" followed by either Code 10 or Code 28.
  7. Code 10 would suggest a potential power supply issue (typically 3.5-inch desktop external drives). If a second external drive with an equivalent power supply is available, try connecting the power supply to the drive.
    NOTE: Before connecting a power adapter that did not ship with the external hard drive, verify that the power configuration matches exactly with the power adapter that was supplied. Failure to use the correct power supply can result in damage to the unit, injury or fire.
  8. If a different power supply is not available, verify the problem by connecting to a different USB port or by connecting to a second PC.
  9. If the same error code is still displayed, create an RMA and return the drive under Warranty.
  10. Code 28 would suggest a driver error.
  11. Expand the "Disk Drive" category in "Device Manager" right click on the drive and select "Uninstall."
  12. Disconnect the external drive, reboot the computer and reconnect the drive when the computer has finished restarting.
  13. If same error is displayed, try connecting it to a second PC to verify the issue.
  14. If the drive fails on the second PC with the same error, create an RMA and return the drive under Warranty.
Apr 06, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
MY BUFFALO EXTERNAL HARD DISK HD PXTU2 IS SHOWING 297 GB UNALLOCATED. I THINK ITS PARTITION IS CORUPPTED
Hi guy,
You can try a partition recovery software to recover your corruptted partition.I have succeed to recover deleted partition with Tenorshare data recovery.It can recover deleted,formatted,corruptted partition after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your partition can be recovered. http://www.any-data-recovery.com/index.htm
Jun 18, 2011 | Computers & Internet
How to recover the permanently deleted files from my 250gb verbatim external harddisc
you can recover deleted files from external hard drive with asoftech data recovery software, you can download the software from
http://www.asoftech.com
Oct 08, 2010 | Verbatim VER95327 USB Hard Drive
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Sybase Adaptive Server Enterprise for Mac OS X 12.5 Logo
96 people viewed this question
Top Sybase Computers & Internet Experts
David Payne
David Payne
Are you a Sybase Computer and Internet Expert? Answer questions, earn points and help others
