Error code TO2-400 risograph rp 3100 ui - Office Equipment & Supplies
2 Suggested Answers
  • 81 Answers
SOURCE: risograph rp 3100 ui
Reset machine... and check connectors to the boards... its a communications error to the digitizer cpu
Posted on Jul 07, 2009
My rp 3700 keeps jamming. It is accepting too many pieces of paper. not sure what to do
Risographs being high speed printers have the separation rollers which if dirty will pull more papers in. Clean the rollers well . Isopropyl helps.
Nov 20, 2014 | RISOGRAPH RP3700/3790 - 2-HI DENSITY BLACK...
System error T01-521
mon riso RP 3100 ep donne le code to1-521. veuillez me trouver une solution merci
Nov 22, 2012 | Riso RP 3700
White stripes on copies
Looks like some dots of the thermal head are defective. So the master at these dots cannot be punched.
Sep 28, 2012 | Riso RP 3700
Risograph 3770 Drum problem
Seems the 'synchronisation' between paper feed and drum ist lost. Maybe you have heard a ripple sound? This means the toothed belt has jumped one or more teeth.Remove back cover loose paper feed clutch to readjust the belt accordingly ...
Sep 03, 2012 | Riso RP 3700
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Jan 08, 2009 | Duplo DP460H Copier
Risograph rp 3100 ui
Oct 13, 2008 | Riso RZ220 Duplicator
Rp 3100 Drum Problem
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
Sep 10, 2008 | Riso RZ220 Duplicator
Riso RP3100EP risograph T01-520 SYSTEM ERROR
riso rp 3100ep electric paper tray not going all the way down properly, Please help!
Apr 22, 2008 | Office Equipment & Supplies
21 people viewed this question
jasbo
jasbo
