Question about Exercise & Fitness
TA sport treadmill E2 error - Exercise & Fitness
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
AJIN G
  • 6694 Answers
SOURCE: I have a Weslo 865
hi,
ur treadmills motor controlling circuit have some problem. that's why it shows e2 or the speed sensor may be oppen . as these potion of ur treadmill is a high voltage point, i will recommend u to consult the manufacturer for support. if u can do it yourself the go for it
ok
Posted on Jan 06, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a lifegear motorized treadmill. After using
1)Alternative: Elevation Out Of Range
2)tsu3fngh4aaaaasuvork5cyii=
Posted on Nov 03, 2011
ercupa190
  • 12223 Answers
SOURCE: E2 error code on my Tempo 612T treadmill
adjust and clean the speed sensor, and tight the connector very well, see the diagram
2) test the input voltage motor, if there are voltage the motor replace
3) test the output voltage board, if there are NOT voltage , the board is faulty, replace.
God bless you
Posted on Nov 12, 2012
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Where can i download a manual for an image 10.4 treadmill? it displays an E2 or E4 error message. thanks.
Try Retrevo Manuals.com lots of manuals but you really have to search for them. Make sure you gave make, model number etc.
Dec 15, 2013 | Treadmill Doctor Image 10.4 Q Console...
Ta sports gs999 treadmill
eu quero codico do pim de 4 letras
Oct 27, 2013 | Exercise & Fitness
Sierra motorized treadmill with e2 code error
E02" You may not have enough voltage going to the machine. Turn the machine off and on
again at the switch at the rear of the treadmill. If this does not fix the problem you may have lower board problem see the diagrams attached and fix it.
God bless you2_4_2013_6_08_21_pm.jpg2_4_2013_6_09_23_pm.png2_4_2013_6_09_37_pm.gif
Feb 04, 2013 | Exercise & Fitness
God bless you
Nov 11, 2012 | Exercise & Fitness
I have a Weslo 865 Treadmill and am getting an E2 error on the Speed display; treadmill will not work
hi,
ok
Jan 06, 2011 | Cadence Exercise & Fitness
Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
May 12, 2009 | Exercise & Fitness
Exercise & Fitness Logo
114 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
