Question about Bernina Bernette Deco 600
Error message i have a deco 600. i keep getting the error message “needle is bent or thread is tangled.” i have replaced the needle and check the thread. nothing seems to work. any suggestions.
  • Anonymous Mar 26, 2014
    Shows error message for tangle thread but won't move o
Tell me what to look at to fix the problem
Posted on Jul 25, 2007
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
Feb 02, 2018 | Brother Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Will not pick up the lower thread
Bent needle (replace with new) or the machine is out of time somewhere (get it serviced),
Mar 04, 2012 | Bernina Bernette Deco 600
I am getting a code that says the needle is bent or the thread is knotted, neither is true. I have changed the needle and rethreaded both the top thread and bobbin. What else could it be
I have a Bernette Deco 600 which was doing the same thing. While it was running it would jam and give this code. If you take the cover off of the end of the top of the machine on my machine there was a rod the needle was connected to. There were two cams attached to this rod, one of the cams was slipping which threw the machine into a jam. Once I pushed the cams together and tightened down the set screw it worked great. Good luck
Nov 19, 2011 | Bernina Bernette Deco 600
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
Bernina Deco 650 Check if upper or lower thread is cut shows on
turn machine off and on to see if message clears... not sure for that machine ( I work with Brother products) but if it has a wiper (small hook shaped blade) that trims the tread automatically it may be stuck in the extended position
Apr 08, 2010 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Problem with threads not catching
Try putting in new needles. Make sure they are in the proper position. There is a stopper which keeps the needle down far enough to make the right connection. Sometimes the needle stopper, after long use, moves up a little which prevents the needle from going low enough to pick up the bobbin thread. You could try lowering the needle just a little. Not to far, or it will break the needle. Sewing machines need a lot of oil. Not all at once but a drop or two after an hour of use. All lint needs to be removed from under and around the bobbin before it is oiled. Keeping the machine clean and oiled is the life of the machine.
Zelma
Dec 26, 2007 | Bernina Bernette Deco 600
Sewing Machines Logo
195 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
