Question about Hoover Microwave Ovens
Broken front glass door panel on hoc704x oven
Hoc704x
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: inside front of oven door is a water build-up
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: broken glass, door model LMA1180ST
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
The best place to order parts for this brand is Encompass (formerly Tritronics).
For this model, I would call them toll-free at 866-779-5835.
Posted on Feb 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: outside glass dooor on Whirlpool oven fell off, what do i do?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can find handy exploded views and order parts by model number here.
Posted on Sep 15, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: The door glass is broken.
It depends on the brand and model.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favoritesWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on May 06, 2010
The door handle is broken on model khms 105ebl0 kitchenaid
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 04, 2009 | KitchenAid KHMS147 Microwave Oven
How to fix a broken handle?
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
NOTE: If your microwave is the same model you have this listed under, I could only find one website that offers the handle as a separate replacement without purchasing the entire door (the entire door cost over $200!). The handle lists for about $51 at repairclinic.com. You can search around, but I have already tried the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Aug 12, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
How do i replace the door handle.
If you have questions about this repair, please let me know. I hope this helps you.
Aug 10, 2009 | Microwave Ovens
How to replace door handle?
The door handle can easily be replaced. This is a common problem with microwave oven doors.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 30, 2009 | Microwave Ovens
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can i replace a broken door handle?
Yes. This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
May 14, 2009 | Kenmore 62702 Microwave Oven
A broken handle on door&how to fix it
If you have questions, or need assistance ordering parts, please let me know. Post back with your Model Number if you need parts assistance. I hope you find this information helpful.
May 13, 2009 | GE Microwave Ovens
Microwave Ovens Logo
Top Hoover Microwave Ovens Experts
jay kaye
jay kaye
Ken B
Ken B
Thomas Aldrin Nullas
Are you a Hoover Microwave Oven Expert? Answer questions, earn points and help others
