Question about Tappan 30-in Freestanding Electric Range White TEF351EW
I have at tappan electric oven with a digital oven control i heard a pop and the oven and the digital display doesn't work now. Pls help
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
RJTech
  • 32 Answers
SOURCE: Tappan oven bought in 1994 / Oven not working...pilot works, burners work
you need to replace the oven ignitor coil.
Posted on Dec 18, 2007
  • 108 Answers
SOURCE: Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Posted on Nov 22, 2008
scottowa
  • 87 Answers
SOURCE: My oven is not workin
I take it this is an electric stove. The display and controller only are used for the oven operation. Check to make sure you have power coming in on all three contacts. If it's electric, it uses 1/2 of the 220 for the burners and the other for the controller. I assume you have already tried un-pluging it and plugging it back in. There should be a tech sheet in the back of the oven. If there is somebody that can read some simple voltage or has a meter make sure power is getting to the controll board. If it is, your controller is probably bad. Hope this helps.
Scott
Posted on Jan 23, 2009
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Tappan built in oven display not working
Find the owners manual and check to see if it has a sabbath day mode if not you will need a oven control which has the display assembly
Mar 17, 2013 | Tappan Ovens
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
My Tappan electric range oven wouldnt shut off tonight after baking dinner. Instead, it flashed ''F1'' in the digital screen, and would not allow cancel to work. What could be wrong? It is a Tappan Dual...
The EOC electronic oven control/clock has failed. This is easy to replace. Go to www.appliancehelponline.com and enter your model # for diagrams and illustrations. All parts come with installation instructions.
Apr 09, 2010 | Kitchen Ranges
Tappan Millennia Electric Oven #316065306---"F1 comes up on digital clock and oven is beeping".
Hi rich750,
The F1 error code description is an electronic oven control failure. The easiest way to fix this error is to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Jul 30, 2009 | Tappan TGF320 Gas Kitchen Range
Digital oven pops breaker as oven starts to light
You have a direct short. A wire or component has touched ground .Gas or electric?electric check connections at bake and broil elements in back.Gas look for broken wire /connection at ignitor or ERC ,(control board)
Jun 20, 2009 | Tappan TGF320 Gas Kitchen Range
Scott
Jan 23, 2009 | Tappan TEF242 Electric Kitchen Range
The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Dec 28, 2008 | Kitchen Ranges
Tappan 30-in Freestanding Electric Range White TEF351EW Logo
65 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
