Question about Apple Mac OS 9.2.1
Is there an equivalent program on apple like regedit?
I'm a new mac user.  How do I access the registry file equivalent from a PC?  (i.e. running "regedit" on a windows based pc... how do you do this on a mac?)
  • tomvene May 21, 2009
    I have the reverse problem. I use regedit on a Mac and know how to debug programs. I would like to do the same on a PC. Is there a PC equivalent to the Mac regedit app?
    Problem Solver:
  • 7 Answers
Yes, not such thing as a global registry. Preferences for each application (or settings like Dock position etc.) are stored in separate plist files. If you used to use Windows 3.1, think of them as .ini files. Content is in a particular XML format and you can edit them with certain text editors such as TextWrangler.
Posted on Sep 17, 2014
    Scholar:
  • 96 Answers
Apple has files that contain the same type of info as the windows registry .
They are referred to as .plist files.
Example:
/Users/YourUserName/Library/Preferences
There is not a typical registry.
Nate P.
Posted on Jan 13, 2009
Error 1402.Setup cannot open the registry kaey. HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{7EA9A8FA-F5D2-49E1-99E8-C26EE07FCEEB}\LocalServer32.
The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
Jun 08, 2011 | Microsoft Windows XP Professional With...
Tip
HOW TO START PROGRAMS IN WINDOWS STARTUP (XP)
Step 1 : Start --> Run --> type regedit and enter.
Step 2 : inside regedit go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
Step 3 : On the right side window, right click and select NEW --> String value.
Step 4 : Now you can see a new file, Give appropriate name Here I'm using Internet Explorer.
Step 5 : Double click the created file and enter the path of the Program you wish to startup. Here i'm using internetexplorer path.
Step 6 : Close the registry editor and restart the machine.
Now you can see the Program was running after login.
Thanks
Current_Support
on Feb 18, 2010 | Computers & Internet
Tip
Why Should you get Parallel Desktop for Mac A lot of PC users are watching...
A lot of PC users are watching closely on the growth of popularity on Apple products. Parallels Desktop for Mac provides an awesome alternative - running Windows directly from within Mac OS X.
The developers have tried to create as seamless an experience as possible, incorporating features like Coherence, which let you open a Windows application from the Mac OS X Dock, and SmartSelect, which lets you open Mac documents with Windows applications (and vice versa).
The benefit of this is it is now possible to run various program like Windows XP or Vista on an Apple Mac computer.
With the Parallel Desktop for MAC, it now enables Apple MAC user to use Windows, Linux, and more side by side with MAC OS or any Intel Powered MAC without rebooting.
There’s a lot of benefits Parallel Desktop has to offer and these includes opening windows file with MAC Application and Mac files with Windows Application using parallel SmartSelect. Share files and folders between Windows and MAC.
It’s now possible to browse windows folder and access files without launching windows with Parallel Explorer. Even running selected PC games on Mac with supports to 3D graphics.
These key features give a lot more convenience to Apple Mac users. Imagine running windows like a native Mac application without rebooting.
Parallel not only gives you free-floating Windows apps in its Coherence mode, but it also drops the Windows Taskbar atop the dock (or you can move it to the top of the screen, under the Finder menu bar).
The Parallel includes a set of utilities that lets you do all kinds of interesting things. There's a migration tool (Parallels Transporter); a program that lets you browse a virtual hard drive without actually launch Parallels (Parallels Explorer); a program for managing the size of virtual disks (Parallels Image Tool).
New to a recent upgrade is SmartSelect, which lets you associate file types with applications on the guest operating system.
For example, if someone sends you a Word document via Apple Mail, you can use SmartSelect to designate the Windows version of Word to open the file when you double-click it.
You can also reverse this, so double-clicking files in Windows causes them to be opened in Mac applications. Even for PC gamer, this has been a big breakthrough because for gamers, the biggest advantage Parallels Desktop 3.0 offers is the ability to run games.
Almost all games in the PC space require 3D graphics acceleration, even the casual ones, and up to now, Parallels has not had any 3D graphics acceleration at all.
on Dec 30, 2009 | Computers & Internet
My computer is SO slow!!! I've had it about 4 years and the fan "breaths" and I don't really have that much file space on it but it's soooo slow. Also, the CD burner doesn't work.
Well, there are a lot of reasons that can consequently cause the issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Learn more: http://www.howtospeedupmac.com/
Dec 26, 2009 | Apple Power Mac G5 Desktop
I got a trojan virus,help
HELLO THERE:
PLEASE GO TO WWW.COUNTERSPY.COM AND DOWNLOAD IT THIS WORKS WONDERS FOR ME AND SEVERAL OTHERS I HAVE HELPED OK?
BEST REGARDS MICHAEL
Sep 15, 2009 | Apple Computers & Internet
Cannot install Office 2007, vista. Tried, tried, tried, for 3 days. Did everything everyone said, nothing works. Can you help me and possibly walk me through it? Thanks Aggie
be very careful when you ask to edit the registry. becasue these are runing files for the operating system. any changes made to the regitry will affact the operation of the system.
to edit the registry. you need to backup the registry before you edit it. just in case something happen you should be able to reverse back.
to backup registry:type regedit in the run box. import & export. select the entire registry and export to a cd, usb, or floppy.then follwoing the direction below.to edit one line. no more, and do not play in the registry.
Click Start, click Run, type regedit in the Open box, and then click OK. In Registry Editor , locate and then click the subkey that is listed by the error message. (in your case, it would be HKEY_LOCAL_MACHINESOFTWAREClassesSketchObj.SketchInk) On the Edit menu, click Permissions. Under Group or user names, click Everyone.Under Permissions for Everyone, click to select the Full Control check box. Click OK. Quit Registry Editor. Run the Setup program for your Office program.
Jun 04, 2009 | Computers & Internet
Error 1311: source file not found:E\LENOVO3000 Y410 USER GUIDE\VISTA\6.LAN\FILES6~1.cab , Verify that the file exists and that you can access it.
The cause of the error is a problem with the Microsoft® Windows® Installer program used by the software. It produces the error when the registry entry AllocateCDRoms at the following subkey is set to a value of 1.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Warning!
Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft has provided a wealth of critical information you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined in ARTICLE-ID: Q132332 "How to Back Up the Registry" in the Microsoft Knowledge Base. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Start the Registry Editor and locate the following subkey:
goto start->run and type regedit to start registry editor
Change the value for the AllocateCDRoms entry to 0.
Exit the Registry Editor.
Dec 28, 2008 | Lenovo 3000 Y410 Laptop
Make my new mac work
If you install the premium version of Office 2008 on your mac, the Outlook Express comes with microsoft exchange server support, allowing you access to the features PC users often require.
Oct 16, 2008 | Apple iMac 24" Desktop
Can't open Internet Expl (reply)
Try this instead because maybe files got corrupted already thats why you are missing some option. but read it first before trying steps
1. Use AOL Uninstall to remove most AOL files
2. Manually search the C:/ drive for all remaining AOL files
3. Run Regedit to edit the registry to find and remove all AOL files EXCEPT
Address Book files.
WARNING: Editing the registry is considered a high-level tech responsibility. New users or users not familiar with the registry are cautioned NOT to do the next step. However, if you feel comfortable proceeding, then:
From Start Menu select Run
In the Run window, Type in Regedit
The registry will be displayed on the left side of a two-panelled window
Select the folder at the top
Under the Edit menu, select Find and type in AOL. click on find or OK
The Find engine will locate the first reference to AOL.
Delete this file; F3 to Find Next and continue until all files are deleted EXCEPT ADDRESS BOOK-related files
When this process is complete {you will come to understand why your pc is slower after installing AOL}, Shut down completely.
Reboot the pc
Use your AOL install disk to reinstall a new AOL system.
The install is prompt you for your logon info and open AOL for you.
Addresses will be retained.
Again, This is not a process for a novice user. The danger is selecting a file to delete that may make your system inoperable.
Apr 22, 2008 | Computers & Internet
Registry
Hi karthee,
Every version of Windows since Windows 95 has used a Registry, which is essentially a database containing the configuration information for the OS, its peripherals, and any installed software. The Registry is among the first things that Windows loads at startup, and it tells the OS everything from how menus and the Desktop should look and feel, to where all the vital files and programs reside, to which hardware is installed on the system.
The Registry actually includes a series of data files stored in different folders in your Windows subdirectory, all according to which OS version you’re using. For instance, in WinXP Home or Professional, the Registry has six files located in the Config folder at C:\WINDOWS\SYSTEM32\CONFIG. Win98 SE and WinMe have different files in other locations, but in all cases, it’s easier to access the Registry via the Registry Editor.
The Registry Editor, the Regedit.exe program, resides in the Windows subdirectory. But the quickest way to open the Registry Editor is to click Run from the Start menu, type regedit in the field, and press ENTER.
Now that we told you how to open the Registry Editor, we should also warn you that it’s unlike other Windows programs because it saves any changes you make on the fly rather than waiting for you to decide to save your changes. Yes, the Registry Editor will save any changes you make as you make them and apply those changes to the respective files and settings on your system. You cannot negate your edits or deletes simply by bailing out of the program without officially saving anything. This means that any user venturing into the Registry Editor must take special care to track any changes made and protect him or herself by backing up the Registry before tinkering with it.
Hope it's help's you.
Enjoy!
Hope to hear more from you soon
tnx
-micro
Feb 11, 2008 | Computers & Internet
Apple Mac OS 9.2.1 Logo
2,232 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
