Question about Sewing Machines
Presser foot lifter doesn't lift on singer 5932
  • 27 Answers
SOURCE: I have a Singer sewing
more than likeley the set screw is loose on the presser bar shaft ,remove the endcover and take a look should be simple
Posted on Jan 10, 2009
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
SewTechWayne
  • 186 Answers
SOURCE: faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Posted on Jan 31, 2009
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Posted on Jan 03, 2010
  • 1788 Answers
SOURCE: my presser foot lever wont
Make sure that your needle is in the highest position, turn your handwheel towards you, not away from or else you will mess up the timing
Posted on Aug 31, 2010
Repairing a Singer Sewing machine presser foot lifter.
Inside the foot the wires are connected to two different screws. They are obviously coming loose by being pulled.
1. Open the foot on the bottom.
2. Look where the screws are. You need to have the wires connected there.
3. Before connecting to screws: tie a knot in the wire from the inside of the foot pedal where the wire protrudes through the hole.
4. Now, tightly connect the wire to each screw. Apply bottom of bracket. Now, sew!!!!!!!!!!
Sep 23, 2016 | Singer Sewing Machines
Can't get my presser foot to fall down when I let go of the lifter on my Pfaff 6085 sewing machine
Sounds as if the spring for the presser bar is broken OR the presser bar is dirty and needs cleaned and oiled.
Feb 25, 2013 | PfaFF Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
How do i re-install the all purpose foot back onto the machine
take the presser bar lifter & lift it up, if you look close it has a small notch under the front
place the all purpose foot down under the presser bar, make sure the presser bar notch get on to the pin that's across the top of the purpose foot & they should snap togeather
Aug 03, 2011 | Singer 3116 Simple
The presser foot lifter on my machine is not engaging this allows the needle assembly to spin - is there a way to fix this?
Your question is not clear. The pressure foot lifter only lifts the pressure foot. It doesn't make the needle spin.
Apr 23, 2011 | Singer 5062 Mechanical Sewing Machine
Dec 31, 2009 | Singer Sewing Machines
Faulty presser foot lifter on a singer 2110/2112.
Jan 10, 2009 | Sewing Machines
On my singer 9005 the pressure foot lifter does not stay in the up position - does not hold the pressure foot up.
These plastic presser bar lifters do wear out a lot ,very common,,,,,,,,You can lift it up and file as close to the machine side on top just a couple of stroke son the file will usually give it a surface to hang on and it will stay up ,much easier than changing the plastic lever
Aug 09, 2008 | Singer 7444 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
