Question about JVC FS-S77S DVD Micro Component Stereo System Shelf System
When put cd in compartment, press play - it says NO DISC
I have put a cd into the compartment and pressed the play, it shows no disc, I have tried several cd's and it always happens, have bought a cd cleaner and that hasn't solved the problem, would you able to assist as I really miss playing my cd's. Thanks
    New Friend:
  • 111 Answers
It seems to be like bad optical picup.you have to replace the picup.
dont do you arent technicaly sound with electronic.
nuwan.
Posted on Jan 13, 2009
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
How do I set free play on my rowe laser100
Hi you put on service , then you enter 84 then you put the number of credit you want by example 9999 and you press popular and you put back to normal mode
Jul 03, 2014 | Wurlitzer Jukebox CD Player
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
Dec 21, 2010 | 2000 Honda Accord
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
Alpine CD Changer - won't read CD
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Fisher cd-rw1000
ah..yes..mi friend, i was in that spot one time. one suggestion i have is-make sure the blank cd you are trying to record on is a "compact disc DIGITAL audio"...or try hitting the "input select" button.
Feb 08, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Error nd after entering cd and pressing play
Have you tried cleaning the Lens? nd means No Disc, indicating that the Lens is not picking up the signal, and so is indicating a 'No Disc'
Oct 22, 2006 | GE Slim Spacemaker 7-5295 CD Shelf System
JVC FS-S77S DVD Micro Component Stereo System Shelf System Logo
153 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
