Question about Kenmore 43052 Front Load Washer
Stains on clothing
I recently did a load of wash and found these strange black stains on some of the clothes. They almost seem like oil. Once they are in the fabric, they don't come out. The next load they are there and a little worse. I looked inside the drum and couldn't find anything. I cleaned the black rubber seal around the door and that didn't help. Not sure what to do now. Any assistance would be appreciated. jonnyzepp
  • 1 more comment
  • Jonathan Forward Jun 15, 2007
    Thank you far all the help. I found other similar problems on this website and determined it wasn't going to be worthwhile to repair my washer. With 3 kids I needed to act quickly and ended up buying a new Frigidaire front loader. I am happy after 1 day and a couple of loads of wash. The unit holds more and is much quieter than my Kenmore. thanks again for the help.
  • Theiceman Feb 17, 2008
    I'm having similar problems. The stains (brownish color) were combined with a roaring spin cycle so the bearing is definitely bad. I'll probably replace the washer rather than repair as I feel the staining is a design issue that will repeat. I separated the rear shell from the tub/drum. On the back of the tub there are 12 small cavities in a circular pattern, each about the size of a thimble. Each cavity was filled with a compacted substance that had built up over the 2-3 years I've owned it. The substance was brown on top. The bearing grease is dark grey. When digging the substance out, it appeared to be undissolved detergent. However, we've only used liquid detergent and fabric softner. So, it may be a combination of detergent, bearing grease and who knows what. My conclusion is to apply the $175 I'd have to pay for a new shell/bearing to a new washer, which is not a kenmore. It took me a half-day to dismantle and I don't want to repeat that every 2-3 years. I'm not sure how long it would take a trained repairman but expect it would have to be at least four hours labor to dismantle, repair and reassemble.
  • Anonymous Mar 02, 2009
    I am disgusted that my just-over-5-year-old Kenmore front loading washer has bad bearings, rust and corrosion down the front, and is expected to cost $850 to fix. No way! I will never buy a Kenmore (or Sears) product again. Whatever happened to quality and workmanship? Now I have to figure out how to get the bearing grease stains out of my clothes.
    Any suggestions on that?
I agree, it is not the rubber bellows, it is the rear bearing. I too replaced both bearings in my washer (I'd suggest a bearing puller to get them out) and the seal (~$70). The washer worked great for about 1 year and 3 months and now the problem has returned. I am not sure if I did a shoddy job with the seal or it is a design flaw. We also had one of the suspension springs break during a wash cycle and this may have caused some bearing damage. We are currently deciding whether to get a new washer or fix. One thing I noticed recently was that the bearings in the Whirlpool duet are different than the Kenmore, they are isolated by stainless steel and not rubber as in the Kenmore. I may try to find these in the same size at least for the first rear bearing which is the one that gets hit with water first.
Posted on Jul 09, 2008
It's NOT the rubber bellows, it's the rear seal and bearings. First the seal fails which allows water to get into the bearings. Soon the water breaks down the grease and then the bearings start making a terrible noise while in the spin mode. The bearings however are NOT molded into the drum but the solution is a bit involved. I changed the bearings (2 of them) and the seal for a total of $67; and about 6 hours of my time.
We've had the washer for about 4 1/2 years and I would do the repair again if we get the noise and staining again, it's worth it.
Posted on Jun 06, 2008
  • 5,911 Answers
Usually black oily stains are a symptom of a rear main drum bearing starting to go bad. The seal goes bad first and the packing grease will start to weep out as water gets into the bearings. Is the washer starting to get loud during any spin cycle? If so, I think your bearing is starting to go. It's not a cheap fix, either. The whole back shell of the outer wash tub has to be replaced because the bearings are molded into the plastic. I hope this is helpful in some way.
Posted on Jun 15, 2007
  • 4 Answers
The problem is the front bellows or seal of the washer. As the washer drum wears agains this seal, it eventually causes it to break down and as clothes brush up aginst the worn spot, black stresk and smears of the eroding rubber actually rub off on the clothes. The smears/stains will come out with comet or another cleanser from most clothes; sometimes it leaves a residual black mark. It is not grease, so a degreaser will not affect the stain.
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful.
Posted on Jan 24, 2008
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
Washer makes stains on clothes
same thing happened in mines i put it though a hot wash with no clothes or washing powder it seemed to do the trick
Mar 16, 2012 | Maytag PAV2300 Top Load Washer
Dark greasy stains after washing
When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail.
The seal wont be difficult to replace,but to get access to it you have to
basically disassemble the whole machine. The hardest part was pulling the agitator off the shaft - I
use a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way - perhaps yours
will be easier than mine was.
Apr 18, 2010 | LG 4.0 Cu. Ft. 7-Cycle Extra-Large...
I am getting oil like stains on my dark clothes that are not on them when they go in but are when they come out and ruin the clothes I cannot get them off. Its got to be the machine
i thought my machine was doing that same thing once. then i found a tube of chapstick in my pants pocket that got washed. that looks just like an oil stain on clothes
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
May 13, 2009 | Washing Machines
Ruining cloths, leaves black stain.
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Dec 11, 2007 | GE WCVH6260F Front Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Black marks on clothes
My wife complained that we were having similar problems recently. After investigation I located the remains of a pen entering the filter and removed this and did a few empty boil washes to remove any remains of ink and this worked for us. Check the filter and hose between the drum and filter.
Mar 03, 2007 | LG WD-16110FD Front Load Washer
Kenmore 43052 Front Load Washer Logo
683 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
