Question about Garden
Honda mower self propelled making clicking noise
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
  • 109 Answers
SOURCE: Honda Harmony mower, self propelled hydrostatic,
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Posted on Apr 26, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Limited self propell
The self propel cable needs to be adjusted. This can be done with a 7/16 wrench. loosen the nut that holds the self propel cable in place. You may need to pry this open with a screwdriver. Don't overdo it or you could break the plastic. Once the cable is loose pull it toward the mower deck, once the slack is out of the cable press the self propel handle in about a half of an inch. This should be close to what it was from the factory. Then re tighten the nut. And check the self propel to make sure it is engaging properly. If you hear a grinding noise when trying to engage the transmission then you will need a new transmission. Depending on if it is a front or rear self propel the part alone is either $60-$75 retail. Most repair shops will charge an hour to do this repair. I hope this answers your question.
Mar 24, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propelled stops working well mowing, I
turn it off,let the drive handle go,pull mower backwards.does it lock the back wheels?if you push it forward,can you hear a clicking noise from the wheels?you should do.lift mower,spin back wheel,should either lock,or click,depending which way you spin it.they have spring loaded pawls that drive the wheel.usually easy to fix.usually dirt,or too much grease.take wheels off,have a look
Jul 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Aug 05, 2009 | Garden
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Apr 29, 2009 | Garden
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
