Question about Bernina Sewing Machines
No power to sewing machine
Sewing machine was working fine the previous day then today when turn on, there is no power - no light, led., motor does not turn.
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
SOURCE: elna 7000 computerized sewing machine
just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
Posted on Apr 13, 2009
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
Foot control on my Juki 2010 sewing machine is not working, as if there's no power reaching it at all. There is power to my machine as indicated by light coming on when main power switch turned on.
Pam, Could be a bad/broken wire, may be repairable, you should take your pedal in to be tested, if diagnosed to be bad you may have to order a new replacement pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Repair the Foot Control on Your Sewing Machine
http://www.sewingmachinesplus.com/foot-control-419451-003.php?gdftrk=gdfV210602_a_7c3285_a_7c15319_a_7cPID513
Sewing Parts Online Search
Juki Sewing Machines
Jun 09, 2016 | Juki Sewing Machines
My Pfaff Tiptronic 6270 does not sew.
Try unplugging the power cord from the machine, let it set for a few minutes and try plugging in again. Sometimes this will reset the machine.
Here are other postings on Fixya that sound similar to your problem:
Pfaff Tiptronic 6270 just stopped working
The memory board went out on my 2000 tiptronic 6270 couple years ago now...
Sep 05, 2015 | Sewing Machines
Led light does not work. how to replace led light on singer 14sh654
I believe the newer machine lights need to be replaced by a technician. You can check on getting some of those LED light strips that can be added to the machine instead.
Jun 24, 2017 | Singer 14SH654
The motor on my machine as slowed down
make sure the power cord is plugged in correctly
and also the foot pedal
if they are plugged in correctly then it's possible that the motor
could be going out or have some kind of a short in it
the machine would have to be checked at a sewing machine shop
Dec 17, 2012 | Brother XL-2600
Is the motor gone in my machine. power coming through
is the light coming on?
do you smell anything around the motor?
it is possible that the motor could be going out.
does it sew any when you push on the foot pedal?
Oct 11, 2012 | Brother Sewing Machines
My sewing machine will not sew
you said the machine was given to you, has the machine ever been serviced that you know of?
is it making stitches?
how is it not sewing?
May 19, 2012 | Sewing Machines
My singer 6038 sewing machine suddenly stops working after sewing for a 5 min. stretch of time. i press the foot down as far as it goes, and all i hear is the motor--but the needle doesn't move....all...
I think that you need a new motor, I saw one online for $90 and it looks like it would be easy to install yourself, mostly plug in and bolt to the machine, I saw it on www.sewingpartsonline.com but there are other sites,
Apr 22, 2011 | Singer 6038 Mechanical Sewing Machine
Hand wheel won't turn and machine won't work
  • Sewing machine has been run at a low speed for an extended period of time.
  • To prevent overheating, motor power is automatically turned off.
Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate, If this by chance doesn't work, Here is a diagram of a typical sewing machine. This fuse should be in the back next to the power box or motor564d4f7.gif
Jan 18, 2009 | Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
