Question about Dometic 2002236004 Refrigerator Part Freezer Housing Spring LH Camper
Dometic freezer hinge housing 2002236004L needs replacing
Can we order both left hand & right hand part
3 Suggested Answers
  • 19 Answers
SOURCE: change right hand door ,to left hand
Not sure with this model but most time you can and I'm sure this is no different, look at the screws holding the hinge bracket, there should be identical screw holes to match on the opposite side.
Posted on Nov 18, 2008
  • 234 Answers
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Posted on Dec 27, 2009
Hi, I have a hotpoint fridge/freezer future rf 175wp and want to change the doors from right hand to left hand hanging. Do I need to get new hinges? Thanks Dave Horn
Dave,
You should not need new hinges. As long as you have screw holes on both sides you re-use the same hinges, just flip the middle one over. The bottom hinge point, you will need to move the post from one side to the other. Hope this helps!
May 07, 2015 | Hotpoint Refrigerators
May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Jul 27, 2008 | Maytag Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
I always get confused as to the door swing direction and I need to replace one of the handle sets. Before I order I need know if it is a right or left hand door. Can you help?
Yes, Here's how. It's all about the hinges. Facing the door from the outside, if the hinges are on the left, and the door swings to the inside, it is a left hand opening door. If it swings in with the hinges on the right, it would be a right hand opening door.
Best regards, --W/D--
Jan 28, 2011 | Garden
Kenmore Elite Oasis Washer Mod #110.27082601 Ser # CT1170582. I went to put the lid down and heard a "pop" type sound, and now the lid won't stay up. Everything else is working properly, and the...
Hello Chrissym1313,
Taken straight from the APPLIANCEPARTSPROS.COM
website... (Left & Right hinge Springs)
Hi--the lid on my Kenmore elite washer does not stay open on its own anymore--from what I have read-sounds like I need new hinge lid springs--can you tell me part #'s and how I would go about replacing those--thnx!!
Mike J for Model Number 110.28082700
Answer Hello Mike. You will need to order WP8580114 and WP8580115 for the unit.
Cross Reference Information
Part Number WP8580115 (AP6013571) replaces 8563961, 8580115, PS11746797, B008DK65SA, B002M647S6, B072YYQ2TQ.
Right hinge spring:
http://www.appliancepartspros.com/whirlpool-hinge-spring-rgt-wp8580115-ap6013571.html
Left hinge spring:
Whirlpool WP8580114 Hinge Left AppliancePartsPros com
Hope this helps
Carnac the Magnificent
Once you have your absolute part numbers... Then you can go SHOPPING... (Left: on eBay $25.50 plus tax & shipping)
New OEM Whirlpool Kenmore Washer Door Hinge 8580114 WP8580114 LH eBay
Right hinge
Amazon com Kenmore Elite W8580115 Washer Lid Hinge Home Improvement
RH hinge on PARTSELECT... ($39.20 plus tax & shipping)
Whirlpool WP8580115 Hinge PartSelect
Dec 18, 2017 | Washing Machines
Dec 27, 2009 | Dometic RM2652 Refrigerator
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Apr 22, 2009 | Dometic RM2452 Refrigerator
Change right hand door ,to left hand
Aug 06, 2008 | Dometic RM2652 Refrigerator
Dometic 2002236004 Refrigerator Part Freezer Housing Spring LH Camper Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
